Home > In Car Electronics > Some Double Din Advice Please.
mcma1
Ok so I will be doing the double din installation later this week. I have already make the cubby box ready for the switches and I am putting in the Alpine unit so apart from extending the wiring will the actual head unit plug into the existed Alpine factory loom??
Thanks
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #462224 11th Oct 2015 9:11am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
My answer is based on mine a June 2015 MY15 90:
The short answer is "yes". Provided your existing factory HU is one of the more modern Alpine units with the black connector.
The longer answer is "yes but" as the factory connector doesn't have all the wires connected that your new HU is likely to have/need. I fitted a different Alpine Double Din unit but for example a parking brake connection is needed (and unless grounded you cant change any settings, presumably a safety measure) which is not on the OEM cable.
Your best bet is simply to get an ISO to Defender connector lead. That way you know you'll be able to use the lead supplied with the HU and connect to the Defender plug.
http://www.defender2.net/forum/topic29061.html
Post #462559 12th Oct 2015 2:46pm
mcma1
Post #462563 12th Oct 2015 2:55pm
Barney12
Yep, just make sure you pick the correct one from the drop down.
Post #462566 12th Oct 2015 2:59pm
mcma1
Post #462567 12th Oct 2015 3:01pm
Barney12
If its for your 2014 110 then yes.
Post #462569 12th Oct 2015 3:05pm
mcma1
Post #462570 12th Oct 2015 3:09pm
dgardel
Italy
Re: Some Double Din Advice Please.
Where did you find the seats/plastic recess of switches you have installed on cubby?
Thank you
Daniele
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #462740 12th Oct 2015 10:30pm
mcma1
Post #462743 12th Oct 2015 10:38pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #462755 12th Oct 2015 11:02pm
mcma1
Ok so all the kit has arrived, fascia is away to get painted so I am going to make a start getting the wires for the GPS, Bluetooth and camera routed. No I got the MUD adaptor which i have connected up, I still have 3 stray wires. Parking brake, remo(amp) and reverse. So do I need to tap into the park brake single lead? And the reverse for the camera?
I want to detail this as much as possible to help others ahead. Smile so please advise!
2014 Corris 110 SW
LS3 V8 build...
Post #463442 15th Oct 2015 11:34am
JWL
Can't help much but the Handbrake lead is what disables the playback of DVD's when the handbrake is off, i.e. the vehicle is moving. The Reverse is what puts the camera view on the screen when reverse is selected. The amp wire is beyond me as I didn't get that technical when I wired mine in.
With my head unit I left the handbrake wire off so the head unit will play at any time and the reverse wire I connected to the switch I put on the dash which means that I can have the camera on at any time, I could use it to monitor a trailer or the like even though reverse is not selected.
Post #463453 15th Oct 2015 12:13pm
mcma1
Thats what i thought, I am going to put a feed from a switch in to the reverse cable as well as the reverse light so that i can switch the camera on if needed as you have done... what about the GPS antenna, do they need to be mounted on the dash or can they be hidden away below?
Thanks Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463459 15th Oct 2015 12:23pm
I'd have the GPS wire near the dash top. After all it's designed to have a near clear sight of the sky. Thumbs Up
Post #463477 15th Oct 2015 1:06pm
mcma1
Makes sense, it will hardly be noticed anyway. Thanks. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463480 15th Oct 2015 1:20pm
