Home > Technical > TD5 wiper park switch (again - sorry)
jamesc
United Kingdom 2005 Defender 90 Td5 XS CSW Bonatti Grey
I hope someone might be able to help. I've trawled the forum but can find no specific answer to my query; how do I get to the wiper motor on a 2005 TD5 90? I have to replace the park switch which I believe is on the wiper motor, but since I don't have a manual I'm not sure where it is.
Thanks in advance
James
Post #46206 24th Nov 2010 7:27pm
Lorryman100
Hi James, go to this link and download what you need:
http://www.landroverweb.com/landrover/pdf-land-rover-manuals/
Post #46220 24th Nov 2010 8:38pm
markb110
Hi James
I replaced mine just a couple of months ago. Its an easy job once you get going Thumbs Up
Good luck
Mark
Post #46224 24th Nov 2010 9:08pm
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
On a pre-2002 td5 it's a fairly quick easy job to change the park switch - I would imagine the post 2002 would be the same:
You need to remove the bottom of the dash on the lefthand side - undo the 4 screws holding it on.
The park switch is then pretty obvious on the side of the motor.. [:O|===|O:] 2001 110 TD5 Doublecab
Post #46249 24th Nov 2010 11:57pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
On the post 2002 dash the motor is housed a little higher up in the dash than the earlier models so a little harder to get at.
Pete.
Post #46259 25th Nov 2010 1:14am
jamesc
Thanks for the replies - very much appreciated. And sorry for taking a while to respond, I've been off air since I posted!
Looks like a finger numbing job outside at the weekend then.
James
Post #46343 25th Nov 2010 8:31pm
