![]() | Home > Maintenance & Modifications > Got my Warns working... |
glad to hear it 2.4 90 XS
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
A nice quality photograph haworthj, particularly in fading light. Do you use a good camera, or did you just get lucky?
haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178 ![]() ![]() |
It's HDR (High Dynamic Range) photography. So it's actually 3 identical pictures taken on a tripod, at -1, 0, +1 ev stops and then all stitched together. The camera is a Canon EOS. There's no post-production apart from the stitching which I really like.
Cheers James |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Nice work James. I use a D300s and love playing with super wide angles (favourite glass is a 11-16 Tokina) , not into HDR that much but every once and a while you do come across good work.....this looks sweet, good stuff. Steve |
Thanks TC. Mucho appreciated.
Jimbo |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
What did you get Gigglepin to do on your winch?
Have seen Jim Marsden winch in action and it is super fast ![]() Brendan |
I was referring to the lights up top. They haven't touched the winch. They wired the lights in for me, and did an exceptional job. Totally waterproofed the wiring. Uprated, waterproof relays. A super neat job under the bonnet.
Oooops sorry, misread/misunderstood post. Warns and Gigglepin I took to be your winch they had worked on. Where is the dunce's corner today??
![]() Brendan |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
Holy illuminated bonnet Batman.....
![]() Looks good, but have you tried driving (for any great distance) with them on? that lit up bonnet will really kill your forward visibility. |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Black bonnet chequerplate for you
![]() + New Defender 110 First Edition |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
How are the lights rigged up? Do they come on only with full-beam or do they have their own dedicated switch? Did Gigglepin run the light cable down inside/outside your RAI? I'd really like rooftop spots.
On Low my Warns reflect on the bonnet on Hi no problem
thats right, on low beam they reflect, but on high, the beam is above, so no problem.
They are wired so that the dedicated switch is operable when i switch the sidelights on. Gigglepin cable tied them neatly in conduit down the outside of the chimney as the kids call it, and then a small hole just behind the bonnet lid, which was then waterproofed. You can't see the hole at all. They recommended this because they said that if the cables went down the inside, then they'd have to drill a hole in the intake in the engine bay to get the cables out again, possibly rendering the snorkel not water tight, which would obviously defeat the object. |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Your Trucks looking great haworthj !!
![]() All this talk about reflections, my Lightforce 170's are mounted on the roof rack too and I don't get any glare from them at all, guess dipped is bound to be an issue though? Gigglepin did pretty much the same with my wires, down the outside of the snorkel and sneak it round the back. |
