Home > Puma (Tdci) > My defender central locking/ immobilised broken
Onmy4thdefender
Hi everybody, please help Ive got a 2010 110 xs and this evening I parked it up set the alarm with the fob as normal and walked away. when I returned I could not unlock the doors with the fob, after managing to get in through the rear door tried to start the engine but just set the alarm off and immobilised the car altogether I tried this for five minutes until finally I could turn the key without the alarm going off but still engine immobilised and very unfortunately I've had to abandon my trusted defender until the morning unless one of you could please please help me many thanks. It seems like when I turn the key I get of a slight jolt from the engine almost as if it has a flat battery but all the dashboard lights are well illuminated the alarm red light is on constantly.
Post #461423 7th Oct 2015 10:27pm
hornet
Careful question: You already changed the battery of the fob (CR2032)? If not, strictly refer to the procedure as mentioned in the manual and try again.
Post #461464 8th Oct 2015 6:59am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Use the EKA (Emergency Key Access) code to turn off the immobilizer if your remote is dead.
It's in the user manual, section "Alarm" paragraph "Disarming the alarm" (page 16).
https://topix.landrover.jlrext.com/topix/c...oupId=1655
Post #461479 8th Oct 2015 8:14am
Onmy4thdefender
Thanks for your reply. I thought that when she was serviced eight months ago they replaced the battery then! I'll check with the garage first thing this morning. I suppose I could use the spare key fob as its not really been used. I'll let you know how I get on in a little while.
Post #461480 8th Oct 2015 8:17am
Onmy4thdefender
Thanks o4dn, I'll try it.
Post #461481 8th Oct 2015 8:19am
Onmy4thdefender
Thanks for all your help. I managed to flag down a Land Rover assistance chap earlier he told me to check the fuse for the central locking which had blown so I replaced it and then take the battery out of the key fob press the buttons for a minute then replace the battery and try again and would you believe it worked first time..!!!!!
Post #461707 8th Oct 2015 10:46pm
Fifth Horseman
Now you need to find why the fuse has blown. The most likely cause is the wiring to one of the door actuators breaking and shorting out - easy to find which one, it will be the door that no longer locks when using the remote.
You then need to get the wiring to that door repaired or replaced.
Post #461744 9th Oct 2015 8:38am
Onmy4thdefender
Yes, it's one of the rear door locks that's not working. Do you know whether this is something I could look at or will need to book it in? Thanks.
Post #461754 9th Oct 2015 9:03am
Fifth Horseman
It should be easy enough to repair yourself, splice in a new section of wire to replace the damaged section. Try to use wire that is meant for repeated flexing and use sealed splice connectors. It can be a bit fiddly routing the wire through the rubber sleeve though.
Post #461764 9th Oct 2015 10:08am
dorsetsmith
common problem
Easy enough to repair yourself, door card off and find out ware the wiring open cct
a lot of the time this in swan neck between door and pillar
Post #461766 9th Oct 2015 10:23am
Onmy4thdefender
Great, thanks, I'll get on to it and let you know how I get on.
Post #461773 9th Oct 2015 10:44am
