Home > Td5 > New drips.
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
New drips.
Hello everyone, today I noticed a small puddle in the garage under my LHD 110 Td5 (right hand side) under the starter. Attached are a couple of pics to show where it travels from. It seems to be running down the outside of the battery cable to the starter and dribbles down to the bolt anchor point on the starter (see pic below). The fluid has no odour I can discern but has the viscosity of diesel.
BOTTOM PIC OF STARTER YOU CAN SEE THE MOIST CABLE
It seems to originate from the fuel pressure regulator, is this prone to leaking? I cannot seem to find any refernce to this happening. Anyway please chime in if you have any wisdom to share before I begin pulling parts off to stop the drip.
TOP REAR OF ENGINE PIC YOU CAN SEE WHERE IT STARTS
Cheers 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #461055 6th Oct 2015 8:14pm
Martin
Site Admin
Common issue on the Td5, either the seals or the regulator unit itself fails.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #461056 6th Oct 2015 8:18pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yep, 99% sure it's the regulator.
Simple little thing.....
But a pain to change too! Evil or Very Mad 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #461057 6th Oct 2015 8:19pm
JWL
I don't know what the spares sources are like where you are but you can get full service kits on the British Ebay or if you feel unsure of your strip down skills as they are quite fiddly then go for a complete one. Just be sure to get the right one for your engine, the 10P has differences to the 15P engines.
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...41714729aa
Post #461062 6th Oct 2015 8:25pm
dorsetsmith
Click on the + Signs to open the Parts Tree !
1 - Connector assembly-fuel block
To (E)10P 15967B
MSO100010 [ 2500 cc - 5 Cylinder - Diesel - Turbo ]
From (E)10P 15968B To (V) ECD3
MSO000080 [ 2500 cc - 5 Cylinder - Diesel ]
2 - .Sensor-temperature
3 - .Washer-sealing
3 - .Washer-sealing
4 - Gasket-fuel connector block
5 - Strainer-fuel filter
6 - O ring
6 - .O ring
7 - Screw - con block to head
8 - Injector & sensor assembly-diesel
9 - .O ring
10 - Clamp fuel injector
11 - Bolt
12 - Pad-insulation
13 - .O ring
13 - .O ring
14 - Connector assembly-fuel block
15 - .Washer-injector sealing
Orders and Enquiries by Email to order@Allbrit.de !
Drawings are for reference purpose only.
THE LISTING OR ILLUSTRATING OF AN ITEM DOES NOT GUARANTEE ITS AVAILABILIT
Post #461069 6th Oct 2015 8:30pm
4RF RDS
Perfect, thanks for the feedback. Spares are always a couple days away. Mine is 200 MY somassume it would be a 10P motor? Used to drive a 300Tdi as my daily driver and I am now getting used to the Td5. Knew the 300 inside and out but was not sure what to get as service spares for this motor still building my parts store LOL.
Any thoughts as to driveability for a few days? Is it going to suddenly develop a massive leak? Am supposed to head out north of Montreal for a few days off roading and camping. Two hours each way to the trail head and back home. I really appreciate the speedy replies! 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #461071 6th Oct 2015 8:32pm
Martin
Site Admin
I had no luck with a rebuild kit, money wasted as the seals were just a teeny bit too small.
To replace the regulator assembly on a 2000 Td5 (10P engine) you need LR016319. Available as genuine, OEM or pattern.
Gasket MSX000010 also needed but some assemblies come with it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #461075 6th Oct 2015 8:37pm
JWL
It's one of those LR things, you can go ages and the leak doesn't get any worse but you may start to get starting problems with a fuelling problem, if it's the pressure valve leaking then the pressure drops and it is harder for the pump to build up the initial pressure. Other problems may arise in that the spent fuel tracks down the cables to the starter motor and can start to erode the starter solonoid contacts but this does take time. Another little foible is that the spent fuel can also get in the bell housing and contaminate the clutch which manifests itself with clutch slip at higher revs, especially in damp conditions. It shows itself more when you are accelerating away from a junction and just as you get to the point you want to change from second to third you become aware of slippage, same with third to fourth and on long uphills.
These "byproducts" are shortlived when you have fixed the leak so don't think that you have a legacy of problems.
Post #461082 6th Oct 2015 8:47pm
4RF RDS
Thank you so much!
1967 MGB GT
Post #461132 6th Oct 2015 10:16pm
4RF RDS
Installed a new OEM seal kit and FPR into the existing housing. Also took the time to change the fuel filter since I had the system opened up. Still no drips since install. Keeping fingers crossed that it will last. Thanks for the assistance everyone.
1967 MGB GT
Post #466381 25th Oct 2015 2:41pm
srod
Righto - I have just done this job, and as per various instructions off the web I removed the o-ring to get at and clean the small gauze filter (from that drawing above: part number 5 - strainer fuel filter).
It came out easy enough, but what I found was the following, it's open at the end (both ends), is this right?
Should the far end be sealed?
Post #467588 29th Oct 2015 5:29pm
