Home > Maintenance & Modifications > 200tdi Head Removal, Inspection, Refitting
Page 3 of 4 <1234>
dorsetsmith
shaggydog wrote:
Right, bits mostly arrived.
Before I fit the head, is there anything I should do?
I am thinking of giving the engine a good degrease, fit the head. New coolant, same oil but run a oil flush and then change oil and filter.
Anything else I should change?
How can you test Glow Plugs?
Post #460004 3rd Oct 2015 7:12am
shaggydog
Thanks for that Dorset Thumbs Up
Will have a go tonight- would be nice to be able to put something original back Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #460548 5th Oct 2015 9:55am
dorsetsmith
How go`s rebuild Question
Post #461471 8th Oct 2015 7:51am
shaggydog
Ok so far Thumbs Up
New gasket fitted.
One of the lift rod tubes had a break in the red line around it. I figured that is was close enough to the bolt and on the low pressure side so I didn't bother with it. What is the red line? I imagine its some kind of silicone?
Head on! Wow, stretch bolts. There a horrible experience! They feel like they are just about to shear off! Chalk helped with identifying as long as my best mate to help point and assist with the angle gauge.
Hoping to get the plumbing for the Webasto sorted tonight bar the fuel lines and maybe get the injectors in and plumbed up. If im lucky i can get the exhaust side prepared ready for the new studs to go in. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #461624 8th Oct 2015 7:10pm
g-mack
huge relief when its on an all torqued up innit Laughing My 109 thread
my youtube channel
Post #461639 8th Oct 2015 7:55pm
shaggydog
Yes it was a huge relief when all torqued and sat down.
Cannot tell you enough how much I'm looking forward to getting back into the cab and turning the key Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #461649 8th Oct 2015 8:12pm
dorsetsmith
Getting along good pace Thumbs Up
be glad you don't have to replace heads on this one
http://www.musclecarszone.com/worlds-bigge...e-respect/
Post #461655 8th Oct 2015 8:21pm
shaggydog
Thanks Thumbs Up
In some ways I would rather be doing one of those head gaskets. Bit more heavy duty!
Most of my mechanical knowledge and skills came from rebuilding steam engines so cars have always seemed a bit delicate and fragile in comparison. The last cylinder block I did up I did up with a flogging spanner and a 8lb hammer so all this torquing up business is very new to me! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #461664 8th Oct 2015 8:35pm
dorsetsmith
At lest your head steal and not aluminum Whistle
i had coolant leak on my one from head right side trend out be easy fix Rolling Eyes
Post #461668 8th Oct 2015 8:42pm
Mo Murphy
Looking good, soon be back on the road 😊
50 Shades of Pennine Grey
Post #461957 9th Oct 2015 10:26pm
shaggydog
I hope so Very Happy
Really looking forward to having it back. I really miss it Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #462547 12th Oct 2015 1:15pm
shaggydog
Big News Big News
Had a good day today, started out with cutting hedges at a friends house which was done quicker than anticipated so I rushed home to finish off work on my 200Tdi.
Everything was ready, the injector pipes were connected up, the fuel spill offs were connected. I filled her up with coolant, bled the fuel system and did some final checks for leaks finding one jubilee clip which needed nipping up. Then with bated breath I tentatively sat in the cab and turned the key.
Click Click Click....... Censored put the battery on charge!
After what seemed like forever there was enough charge in the battery to try again.
Turned over a few times and then with a cough and a splutter she burst into life!
The relief was enormous and after a few checks I tentatively had a trundle up and down the drive to make sure all was well.
I let her get up to temperature and then turned off so she could cool down so I can have another check over.
What a relief!
Now just need to get the fuel system for the Webasto sorted out and I will be very happy!
Felt sooo good to be back in the driving seat again. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #464173 17th Oct 2015 9:30pm
g-mack
here's to the next 180k miles Thumbs Up My 109 thread
my youtube channel
Post #464175 17th Oct 2015 9:34pm
Mo Murphy
Thumbs Up Excellent news !
Post #464217 18th Oct 2015 12:02am
Triggerfinger
Well done sir good job Wink
Post #464219 18th Oct 2015 12:10am
Page 3 of 4 <1234>
