![]() | Home > Technical > Rear Door Size |
Hi Dave,
Just measured it on my 90 if you are on about the Safari door? If not I haven't any rear doors and you'll have to wait for someone with a 110? 91centimetres width at the widest point at the base. 113 centimetres tall. 10 centimetres thick with door card and handle fitted. ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 1st Oct 2015 10:18am. Edited 1 time in total |
bigdave Member Since: 13 May 2010 Location: Cornwall Posts: 342 ![]() ![]() |
Top man thanks very much.
See edit above. Measurements were for Safari door. Backed up with phone call to Dave.
![]() It is rear passenger door sizes he's after. Anyone????? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 1st Oct 2015 10:24am. Edited 1 time in total |
Thanks chap - I should have said I need it for the passenger ears doors say on a 110.
Note to self to be clearer!!! |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Hi Dave. 45" x 30" x 3.5"
Do you need the weight? I still haven't put my 2 new ones on yet, could throw on the scale for you. |
