![]() | Home > Technical > loss of power |
On my 2001 TD5 the fuel gauge will drop to zero when starting if the battery is low.
Check battery state and the battery connections and earth. Also check for oil in the ECU loom (unless that is what you meant about changing the main loom ?) TD5's do not like low batteries ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
davec Member Since: 09 Sep 2015 Location: Devon Posts: 8 ![]() ![]() |
Thanks for the reply Bob.The loom was changed in the hope the fault would clear.I'll mention about the fuel guage/battery link.It just seems strange that it cuts out after a couple of miles,as if a component is breaking down under load?
Did he pull the red plug on the ECU and check for oil ?
Also, the crank sensor may be shot and/or missing it's spacer or not even connected ? Turbo waste gate actuator may also be stuck. All easy to check and fix. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
No oil around the red plug.I will mention to him what you've suggested and post if successful or not.
Thanks very much for your help. |
How about the ecu earth plus its integrity back to the battery?
Reading it again I would put money on the injector seals and washers. Replace them with quality ones and see what difference that makes. |
Thanks very much,added to the suggestion list.
Still got the problem.The ECU has now been away to be checked.Can we just assume that this is ok so we can look into other possible causes rather than me posting tomorrow night saying it hasn't improved as I'm able to help in the morning.
Many thanks in advance for any suggestions. |
Dpgdefenders Member Since: 11 Nov 2014 Location: North Yorkshire Posts: 9 ![]() |
Have you run a separate new Earth from the ecu Earth terminal stud to the battery neg terminal? Sounds bad earthy.
I'll do that,we're getting desperate now.Mate's nearly bald,pulling his hair out.
As a bit of a curveball, the guage dropping may be a bit of a red herring as the guages will drop when cranking as the circuit is cut much the same as your radio will go off when cranking. It may be the age old injector seals and washers and not an electrical thing after all. Well worth doing if they haven't been changed for a while.
He changed all the relays,4 yellow,2 black and it's running.I can only think that he may have changed the wrong relay thinking that he'd done the one for the fuel pump.
By changing them all,this time he did swap it. It is running,as I've mentioned,but, it needs the accelerator pedal to the floorboard before it picks up. Thanks to everyone who commented and any further thoughts would be appreciated. |
Personally, I'd still be looking at replacing the injector seals and washers.
I'll suggest it to him,thanks for reply.
