Home > Technical > rear end bounce steer.
jonnytatt
United Kingdom 1988 Defender 90 300 Tdi SW Nato Green
Hi this morning I hit a hole cornering and the rear end seamed to propel me violently into the turn, looking under Neath when I got to work with a small screw driver I noticed the A frame Bushes to the chassis can be moved easily side to side and a touch other ways.
Question is how much movement should there be here and would this even cause a slight throw in turn if they was worn .
Every other bush on the vehicle including shocks is new within this year thanks
Post #457033 22nd Sep 2015 9:12am
uncas
Jonny, Check the locking nuts on the rear radius arms, one may not be tightened up allowing the axle to move forwards and backwards.
Uncas
Post #457134 22nd Sep 2015 3:38pm
