![]() | Home > Maintenance & Modifications > 2007 Mantec Snorkel |
| banstock Member Since: 04 Aug 2007 Location: berkshire Posts: 10
Just fitted the new Mantec Snorkel
What do you think ![]() |
| Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204
looks a bit like a gypsy caravan chimney to me.
but i think it's because of the angle of the photo |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Yep, if its the one I was lusting after at Billing it looks better from the side.
Is that better |
| Le Rodent Noir Member Since: 16 Aug 2007 Location: Essex Marshes Posts: 23
Definitely better
Le Rodent Noir. Le Rodent Noir. |
I will never be able to look at my 90 face on without thinking gypsy caravan chimney |
will this ease your gypsy tendancies?
It works the same as the old Mantec mushroom with the intake around the base but it also has that extra bit at the back that you can see
| waterman Member Since: 14 Aug 2007 Location: Western Australia Posts: 6
Very nice, howed you go with the lower left bolt, resort to child labour to get it in ???
The captive nuts failed as always
had to take the pipework out from the inner wing to fit normal nuts, child labour for a full day as the ABS/TC unit was also in the way. |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803
How easy are these to fit please and is any drilling involved?
Just removed the RAI from the D3 and had to get a repair fill and paint job to the 2 holes left in the wing. Andy |
| Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119
Need a drill and a steady hand for the first bit and then a captive nut tool/press, didn't have any problems fitting it and I am no mechanic. Had a bit of a blonde moment when I opened up the box, but a bit of a think and a phone call to AndrewS to make sure I wasnt a basket case with the instructions and it was fitted! 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
Sounds like the same method as the D3 install, 2 x captive nut brass thingies above the wing duct? Andy
| All times are GMT |
