![]() | Home > Maintenance & Modifications > Non bulkhead options for half height barrier? |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
You say you have a full height guard - is it a genuine LR 2 part? if so, can you just use the bottom half?
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
No you can't as there's no brackets to support it at the mid height 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
There is on my LR fitted one (90 SW).
Picture? 2016 D4 HSE
can get photo tomorrow, but there should be a few on the internet for standard LR barrier. See fitting instructions http://topix.landrover.jlrext.com/topix/co...3Dlr006448
The bracket is on top of the wheel arch boxes. The biggest issue is the stupid design that leaves two sharp "tabs" sticking up when the top half is removed. Why they didn't put these "tabs" on the removable part I'm not sure. Some pipe lagging or similar might tidy it up. |
You see that's my point, yes the dog guard is fixed on top of the wheel boxes but not at the top of the middle section, where those tabs are. It's not stable or secure.
And anyway, the one I have won't even line up with the wheelbox brackets, something isn't right. I had a whole thread about it, no one can seem to fathom why my brackets don't sit where they should, it's all OE equipment! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Ok, it was just a thought.
Mine seems fine stability wise with the top half removed. |
