![]() | Home > Maintenance & Modifications > Securing Ardcase when driving |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
I like the first solution in the below thread. Good reminder to ask about it, high time I finally get this done.
Eric http://www.defender2.net/forum/topic25192.html?highlight=ardcase You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Now that I'm reminded of this, just ordered 2 sets of these Quick Fist rubber tie down belts from amazon.com in USA. Total price including shipping remains well below the Swiss threshold for import VAT, so no other charges here. Even cheaper than if I would have ordered them on amazon.uk or amazon.de.
Just in case of any interest, here is the link to the correct item: http://www.amazon.com/Quick-Rubber-mountin...belt+38%22 When I will install it for the Ard'case, will see if I only need to use one set (from charliefox post seems the case), or both sets. If only one, I may offer the second one up here. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Thanks Eric
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
Yep, I've used the quick fists on the roof rack, with a home made bracket, for two years now. They hold my shovel and axe, when we go away.
I can't fault them at all, they are exposed to all the elements and still look as good as new. Initially I was told that they may degenerate when exposed to excessive UV. Though on the packaging it states that they are UV treated. I guess that won't be a problem for you anyhow. Very easy to operate, and a big ![]() |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
Ardcase can be secured just with a ring/lynch pin on the side of the seat box using the clip for the lid.
It doesn't get in the way unless you have large feet! Picture in my gallery: ![]() |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Ah bought an Ardcase at Peterborough at the weekend, and need a solution like this. Then I just need another solution for the ENOURMOUS key they give you
scotm, not sure I understand exactly how you fix it there. Any more detail?
Hufflepuf, here is my solution for those enormous keys... Not sure it really is what you are after though. ![]() ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
