- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Rickydodah
Re: did you do it yourself? | |
kweese wrote:How difficult was it to punch out the old ball joint assembly?
In my opinion unless you're very lucky you're better off buying the fulcrum arm and joint as an assembly. Even the loosest ones I've come across needed a fair amount of pressure to remove them. If your paying someone to do it you're likely to save on labour costs by replacing the assembly. My local indie groans at the thought of replacing the joint on its own as he's only got a 20 tonne press and this is sometimes inadequate he tells me. I started with nothing and still have most of it left!
20th Sep 2015 11:20am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
