Home > Puma (Tdci) > G-Klasse Mirrors
dgardel
Italy
G-Klasse Mirrors
Installed today, heated and electrically adjustables
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #456453 19th Sep 2015 11:59pm
ericvv
Daniele, surely a very clean installation as per those pictures, but I still am not sure about the looks of those G-class mirrors on a Defender. Anyway, looks are very personal of course, comme tu sais, les gouts et les couleurs on ne discute pas. Laughing
Can you explain a bit how/where you connected the heating elements? Also it would be nice if you could post pictures of where you installed the electric mirror command button on the dash.
Peronally have to admit that I am more tempted by the dutch "landreiziger" door mirrors which can have heated elements (I would intend to connect those heated elements in line with the rear window heating, so no extra switch is needed). And those also can have built in turn signal repeaters. Whistle
That is my preference of course, primarily because they are absolutely standard looking. Cool
Still, well done. Thumbs Up
Eric
FYG - here is the link to the landreiziger mirrors I am talking about.
https://shop.landreiziger.nl/modificatie/m...ender.html You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #456555 20th Sep 2015 2:17pm
You know landreiziger" door mirrors are from All makes 4x4 the mirror glass is thin the rubber bead does not fit quite right
In all not impressed until you turn them on heaters are better than what I've tried in the past as before current draw 1.5ish per side Mud ones .7amp
These will stay on the Bowler for winter the ABi'll fit Mud ones Thumbs Up
Post #456564 20th Sep 2015 4:12pm
dgardel
Italy
What are "landreiziger door mirrors"?
Ah! found it
https://shop.landreiziger.nl/modificatie/m...ender.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #456652 20th Sep 2015 9:45pm
Bingo
Russia 2005 Defender 90 Td5 HT Santorini Black
Daniele, do you have any photos of the process of installing mirrors on the door?
Thanks!
Post #886356 18th Feb 2021 6:02pm
