Home > Technical > Something Loose on Rear end
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
I seem to have something loose in my drive shaft somewhere or something. I'm not a mechanic.
Basically, when I release the clutch I feel a clunk and something is loose when I disengage the clutch. I can slowly release the clutch and minimize this though. Also, when I'm coming to a stop and the car is still in gear, it clunks again as if something isnt tight. Sometimes when I'm coming to a stop it also feels like something is sliding out from under the car. Any suggestions on where I should start trouble shooting? The Rear Splines have been replaced and this didnt really solve the problem.
Shocked Shocked Shocked Shocked
Sorry bros... It's a TD5 110 1999
Post #455090 14th Sep 2015 9:18pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
As a first port of call I would check your prop UJs and A-frame ball-joint then all the bushes.
Post #455111 14th Sep 2015 10:11pm
kevinf
hi
you didn't mention what model defender it is? a quick check would be the half shaft drive flanges just pop the rubber caps off the centre of the wheels, with the hand brake on try and rock the rear wheels back and forth and see how much free movement there is in the splines excessive wear in this area is very common and cheap to rectify! though some 90 models have one piece half shafts so this may not apply
hope this helps
Post #455180 15th Sep 2015 10:16am
Mo Murphy
I'd put my money on the A frame ball joint. Take a look at the trailing arm bushes too.
50 Shades of Pennine Grey
Post #455201 15th Sep 2015 11:53am
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
Changed the A frame ball joint/bracket complete, last week, the change is massive, no slack in the drive now, well worth it for 30 quid.
Post #455203 15th Sep 2015 12:11pm
mk1collector
Also check drive flanges Ray
My build thread
Post #455204 15th Sep 2015 12:13pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
remove bowling ball from back of wagon .....
Rolling with laughter
(sorry - its just my humor - I'll get my hat....)
Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #455205 15th Sep 2015 12:19pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
LOL'age Rolling with laughter Bow down
Post #455320 15th Sep 2015 7:40pm
Triggerfinger
Not planning a trip to the Uk via france ??
You could get some importee's at Calais to hang on underneath and tell you what's loose Rolling with laughter Rolling with laughter
Il bet you get plenty of offers Laughing
Post #455374 15th Sep 2015 9:53pm
kweese
I saw this part on paddocks
Part Number DA1129ULTRA
It's high articulation. Would this be ok with stock suspension? It's britpart- Censored ? Or would I be better off buying the lemford one and pulling the old one out of the fulcrum bracket?
Post #456366 19th Sep 2015 7:11pm
bob neville
Leave the ****part one where it is and get one of these Thumbs Up
http://www.gwynlewis4x4.co.uk/product/a-fr...n-housing/
2013 Defender 90 CSW - sold
Post #456420 19th Sep 2015 9:29pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Not sure high articulation A frame ball joint will do much if you are running stock retained springs. Even with a 2" lift, your articulation is being limited by the amount of drop you get.
Post #456478 20th Sep 2015 6:51am
Caterham
Did my A frame ball joint yesterday with stock item. Great improvement - just surprised how much of an improvement it can make.
Good luck.
Post #456480 20th Sep 2015 7:25am
kweese
did you do it yourself?
How difficult was it to punch out the old ball joint assembly?
Post #456488 20th Sep 2015 8:16am
Caterham
Replaced the whole thing incl fulcrum.....understand they aren't easy.
Post #456496 20th Sep 2015 9:05am
