Home > Maintenance & Modifications > Noisekiller
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Noisekiller
Well, now that I've finally finished fitting a full NoiseKiller kit (including under bonnet and rear panels) to my Puma 110 USW, I can give an honest appraisal. Only thing I wish I'd had time to do (but didn't) was to record the same drive 'before' and 'after'.
Impressions:
- Has made a BIG differerence!
INterestingly, when I was fitting it, the total effect crept up on me slowly (I fitted it in several stages). It's subtle but brilliant.
- From my point of view, if I was driving the 110 on my own, I could live with the factory level of noise (especially since the XS has a little more soundproofing than base models), but..I travel with others, and it has made a big difference to my ability to hear back seat passengers and conversations.
- Have had to adjust the stereo. Have actually had to add more high frequency sound! Before, the sound was harsh and sibilant no matter what. Down 5 steps on the volume!
- You can still hear the clatter of the engine, and the clonk of the gear linkage, but it's a bit more muted. Not like a Bentley, though!
- Doors now make a 'clonk' sound rather than a clang. This despite not having fitted the panels to inside of doors yet. The difference is that the interior doesn't echo!
- The bits of the kit that made the biggest difference (in order) were:
1. Rear floor, and lower panels.
2. Under Bonnet
3. Seat boxes and gearbox tunnel.
4. Middle row seat floor and bulkhead.
5. Rear side panels.
6. Bellhousing.
Still to fit panels that they supply to inside of doors. Toying with the idea of their lead blanket for under bonnet....
Suspect to get perfect improvement in sound levels I'd need to fit the Nakatanenga door seals and clad the engine bay side of the bulkhead.
Massive improvement as it is, though!! Almost saloon car-like levels of noise.
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #45474 16th Nov 2010 8:09pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Do you place the sound killer stuff behind the original land rover trim or does it replace the land rover stuff?
Many thanks
Pete
Post #45478 16th Nov 2010 9:30pm
Sorry if rude but how much was the kit ?
Post #45480 16th Nov 2010 9:57pm
szracer
Hi Pete,
Yes, I placed it behind the LR trim. The only place I didn't was on the bulkhead, and front bellhousing, as the LR original felt there is already quite thick.
Apart from that, I figured 'the more layers of soundproofing the better'.
In fact, in the case of the front floor, I had about 2cm thickness, including the noisekiller stuff, LR carpets, plus rubber mats.
And yes, I did check that I still get full pedal travel!
One big advantage of the Noisekiller stuff is that it's not felt, so won't soak up water.
I realise this is probably not to 'hardcore offroaders' taste, but then the whole idea of the Defender is that it is put to use in myriad ways. IN my case, this means wading only in an emergency, and mainly gentle greenlaning, getting me through snow and ice, towing a trailer, plus getting me up a hill to judge the Cotswold Olimpicks!
Many thanks
Pete
2005 Ducati ST3
1954 Sunbeam S8
Post #45481 16th Nov 2010 10:00pm
szracer
£280, plus £65 for the rear panel pieces.
Not cheap, but for me makes the Defender a whole lot pleasant!
I'd looked at the Wright Off-Road stuff, but is not for Td4s and is a bit more 'utilitarian'.
With the USW's rear panels, I'd actually already fitted a TGE kit, but not too impressed with that. Just ome bits of plywood covered in carpet - even I could have rustled that up, and they keep falling off.
Am going to fit noisekiller behind those panels, then stick them properly!
2005 Ducati ST3
1954 Sunbeam S8
Post #45483 16th Nov 2010 10:07pm
leeds
Mudstuff Uk are now doing panels including acoustic pads for a 90 hardtop.
Believe 110 model is on the cards so to speak.
HTH
Brendan
Post #45487 16th Nov 2010 10:41pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
HTH
Brendan
i have the mudstuff panels in my 90, a bit of a pig to fit but well worth the effort and the sound comfort level and overall comfort feel has improved so much.
Post #45498 17th Nov 2010 7:54am
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I have the TGE panels in my 110USW and they have never fallen off and blend in very well with the rear. I think they were about £100 for the set, 2 side panels, each made out of two pieces with a plastic finisher to go over the box section in the middle of the panel and two small panels to cover the rear quarter lights. I was very pleased...
Post #45501 17th Nov 2010 8:08am
Grockle
fitted it to our XS very good quality and fit 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #45525 17th Nov 2010 11:14am
szracer
OK - Maybe being a little harsh on theTGE panels.
However, they do keep falling off on mine. Maybe I fixed them wrongly?
Are they supposed to sit under the plastic trim at all?
2005 Ducati ST3
1954 Sunbeam S8
Post #45552 17th Nov 2010 12:27pm
bob neville
I've got the full Noisekiller kit fitted to my double cab and agree with James, it does make a big difference to noise levels.
In the DC the rear floor and the area under and behind the rear seats seem to have the most drastic reduction in noise level.
Well worth the money Thumbs Up
Bob
Post #45590 17th Nov 2010 6:21pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Would the door panels be affected by Waxyoil cavity wax application, or would you remove them beforehand?
Post #45596 17th Nov 2010 6:51pm
BigRuss
Just had a look on the website, it looks pritty good.
Not that it's a bad thing but surely with the extra padding/insulation it would help keep the landy cool in the summer with the ac on and then warm in the winter. Thus helping save a bit of power. Russell
2011MY 110 XS USW Black
Post #45601 17th Nov 2010 9:03pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
When you buy the kits do they come Land Rover shaped, or do you get sheets that you need to cut yourself? Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #45618 18th Nov 2010 12:26am
landy andy
Noise killer mat kits are cut to size, numbered, and then listed with their location.
I brought the full kit and a complete sheet, and covered the back of my truck, over all the mobile storage kit. Made huge difference, even stopped the "crap your pants" moment when stone is released by tryre, and no rain noise. And covered all other areas that I could find.
Andy
Post #45631 18th Nov 2010 8:48am
