Home > Maintenance & Modifications > Brake disc quality.
Page 2 of 2 <12
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I'm not wanting bling factor just best stopping power. I was planning on putting grooved and dimpled on it as that what it has from previous owner. So what will be best for my 130 that will be up to max weight on a regular basis and see a bit of mud. Will there be any difference between these,
httrp://www.paddockspares.com/ftc902m-brak...intex.html
Or a more expensive set like these,
https://ebcbrakesdirect.com/Store/Automoti...rettyPhoto
Post #454674 13th Sep 2015 2:35pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
For no other reason than you say it will see mud I would go with either a plain or vented disc not a textured surface one simply because such surfaces will potentially hold more mud and this will act as an abrasive on both the disc and pads causing premature wear. Rhubarb and custard let fly with their secret weapon.
Post #454692 13th Sep 2015 4:29pm
Well at £52.80 vs £92.90 or £154.07, then i think I'd be starting with a set of the cheap ones and see how you get on. If they do the job then you have the spare money in your pocket; and if they do not then you can move on to a different type/brand. The Mintex information is particularly poor on Paddocks (and others websites).
Post #454870 14th Sep 2015 8:34am
Page 2 of 2 <12
