Home > Maintenance & Modifications > Front mudflaps
CarMan
Front mudflaps
My 200tdi has none and no holes as far as I can see in the outriggers, but I would like to fit - so do I have to drill and fit rivnuts, or am I missing something? Happy to provide pics if it helps. Thanks.
Post #453738 9th Sep 2015 8:25pm
Easier to fit a Gwyn Lewis set up - available on our website or from GL direct
Post #453765 9th Sep 2015 9:04pm
landy andy
Personally I would not drill and fit standard stuff, I'd fit the Gwyn Lewis kit.
Post #453766 9th Sep 2015 9:05pm
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
These do look a lot better, they also do other good protection flaps
Post #454075 11th Sep 2015 7:58am
shaggydog
I would be wandering why there were no holes for the rivnuts- to me it sounds like it may have had an outrigger replaced at some point.
If you want to stay standard then yes, drill holes, paint the edges and then insert riv-nuts
Alternatively the Gwyn Lewis ones seem to be popular Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #454127 11th Sep 2015 12:54pm
CarMan
I really like the look of the GL ones, especially as they are easier to fit, but want to stay standard. I don't think the outriggers have been replaced, do you SD? I just assumed they came out of the factory without and were dealer fitted. Waxoiling is on the list!
Post #454190 11th Sep 2015 5:04pm
shaggydog
Interesting!
Mine were pre-drilled but no Rivnuts so I assumed they were all like that.
Yours look original though, just give them a bit of a scrub up and spray with some ACF-50 to try and keep the corrosion at bay. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #454512 12th Sep 2015 7:25pm
CarMan
Thanks, I'm very pleased that you think mine look original which is pretty good I reckon after 22 years and all the stuff you hear about Defenders - and though I suspect mine has not been abused, it certainly has not been cherished by its 3 previous owners Neutral
Post #454522 12th Sep 2015 8:14pm
shaggydog
Looks in good nick Thumbs Up
Don't worry, mine was stood on axle stands and used as a shed for storing leaflets for a year by its previous owner Rolling Eyes
It was also stored mostly in a yard when not "out and about" and main dealer serviced all its life so bit of plus, bit of negative.
Rest of the chassis look as good as that?
How about the bulkhead? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #454535 12th Sep 2015 8:47pm
CarMan
SD
Sorry for the very slow reply! Chassis all good apart from a little bit where the chassis rails meet the rear crossmember (original) which has been patched badly. Bulkhead shows no signs of corrosion. Any chance you could send me a pic of your outriggers so I know where to drill the holes Rolling Eyes
Post #462285 11th Oct 2015 3:18pm
