![]() | Home > Maintenance & Modifications > Defender 2.2 PSI Power Box |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Hi Guys,
Has anyone used on of these on there 2.2 and if so are they good or just rubbish that will cause problems? http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Cheers Stu |
Hi Stu, hopefully this will contain enough infformation for you to bin the idea, save your money and do the right thing with regards tuning enhancements.
Phone Devon 4X4 and ask "What's in the box?" It may just be a resistor that fools the fuel fuel rail into thinking it's under-pressurising and as a result gives you the power gain by simply throwing more fuel at the engine. These plug and play boxes have undoubtedly come a long way perhaps but it is something I personally would never consider when there are proven and safe alternatives. They are cheap for a reason, primarily they have not had the expense of time and money in development. ![]() **Edit** Found these that may confirm my theory about just dumping more fuel at the engine..... http://www.psi-motorsport.com/turbodiesel/powerbox-e.php https://www.landyzone.co.uk/land-rover/psi-power-box.115301/ Another thread on the same subject albeit not a 2.2. http://www.defender2.net/forum/topic33150....+power+box Martin's spin on tuning boxes..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Cheers Mal, if you dont like them then im not interested
You're very welcome. You are correct in your assumption about me not liking them......at all!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 415 ![]() ![]() ![]() |
Vanntuner is the top man in the transit circles he's also very good he's very good and a perfectionist he will keep rewriting the map till he's happy it's 100%
