Home > Maintenance & Modifications > Sikaflex 221
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Sikaflex 221
I will be bonding a long stainless bracket for the raised air intake vertically on the windscreen pillar, anyone think that is wise ? And will work ?
Mainly as I really don't want to drill the pillar as it's brand new
Any other ideas or sealents/ bonding agents appreciated
Post #453734 9th Sep 2015 8:22pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Silkaflex is great stuff, I used it to seal the hard top to the body cappings due to a leak, worked very well, just make sure you have something wet like a damp J cloth when doing it, it's easier to wipe and get smooth with something wet or damp, like when plumbers lick their fingers when sealing the edge of the bath.
Post #453748 9th Sep 2015 8:42pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
If you are expecting to bond the bracket you will have to 'key' both the bracket and the area the bracket is to be bonded to, or else eventually the bond will break.
Thumbs Up Thumbs Up You only have one life, live it....forget the cost.
90XS Hardtop
Post #453769 9th Sep 2015 9:11pm
Roy5695
My snorkel is bonded to the frame with sikaflex. I didn't etch the surfaces. Still stuck. Just left it to cure for 24/36hours held in place with a ratchet strap.
Post #453775 9th Sep 2015 9:25pm
I'd have thought a glossy surface would be a better bond for a sealant / adhesive in this instance with less possibility of moisture getting behind it.
Post #453793 9th Sep 2015 9:50pm
Roy5695
I don't know but my fish tank certainly ain't etched/roughed up where the joins are and there's 400kg of water being held in by the sealant. So my snorkel being attached the same way worked for me.
Sikaflex sets upon contact with moisture. So shouldn't be a problem.
Post #453798 9th Sep 2015 10:11pm
Triggerfinger
Silkaflex is great gear I use it all the time although it is very strong & works well as a bonding agent
for a while, I would be looking for a more permanent fixing, but it saves drilling unwanted holes in the
body work!! When you come to finishing off the beading have a spray bottle with some fairy liquid
& spray the Silkaflex & your hand then run your finger along the bead it will give you a nice smooth finish
plus it wont stick to every thing you touch Thumbs Up
Post #453799 9th Sep 2015 10:13pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
You can buy it in Screwfix it's Sika EBT,I used quite a few tubes when building my camper van,stuck the solar panels to the roof with it .You do need a minimum of 2mm thickness of Sika though.
Post #453831 10th Sep 2015 7:03am
need4speed
Sikaflex is the real deal. That bond will outlast the rest of the defender.. Laughing
Post #453833 10th Sep 2015 7:09am
K9F
I have used the same Sikafelx for exactly the same application and it has worked a treat: Thumbs Up
K9F wrote:
When I fitted mine the instructions stated to drill the holes out to 16mm. With careful alignment the smallest you can get away with is 12mm, use a stepper/cone drill and start at 8mm gradually taking it out until you are happy with the alignment. I also would not drill the pillar. Over time the pillar bracket deteriorated slightly, I eventually had a stainless bracket made and sealed it to the pillar with Sikaflex, doing this from the start would negate the requirement to drill.
Replacement bracket...
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #453850 10th Sep 2015 8:33am
Happyoldgit
Sikaflex is brilliant stuff but think about the job logically, you are not gluing the bracket directly to the screen frame, you are gluing it to the paint on teh frame. Therefore the bond to the screen frame will only be as good as the bond the paint and primer has to the frame itself..... Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #453884 10th Sep 2015 10:47am
mikeh501
my snorkel isnt the same as that but i used small stainless nuts and bolts to hold the bracket onto the window frame (with v.careful drilling) and then a blob of sikaflex to make it all watertight.
Post #453912 10th Sep 2015 1:09pm
