Home > Maintenance & Modifications > Speaker recommendations for 200tdi hardtop
CarMan
I'm not looking for anything fancy and preferably with the minimum install required due to my own very limited ability but I have now ordered the Alpine CDE-173BT (thanks to the recommendation here) and I'm wondering if anyone can offer some speaker tips?
As you can see mine are stuffed and in the (horrid and to be replaced) headlining and the existing head unit is in the dash (which is where I am hoping to put the new one) but should I put new speakers back in the headlining or if not where, without too much wiring - and either way, which speakers Question
Thanks Rolling Eyes
Post #449774 27th Aug 2015 6:20pm
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
On my 200tdi I mounted speakers in the rear, each side of the back door, above the little windows in a mount made from plywood that I screwed to the lip that joins the roof to the roof sides. There is just enough space there to fit 6x9's in. Sorry no photos though...
Post #449829 27th Aug 2015 8:53pm
Retroanaconda
Under the dash is the standard location.
Works well enough Smile
Post #449844 27th Aug 2015 9:35pm
CarMan
That's good for me, thanks - is this type standard, or something else?
http://www.ebay.co.uk/itm/271947551414?_tr...EBIDX%3AIT
Post #449849 27th Aug 2015 9:40pm
Retroanaconda
I think standard ones are 4" or thereabouts?
Post #449852 27th Aug 2015 9:43pm
CarMan
Sorry, a bit slow adding the link Rolling Eyes
Post #449853 27th Aug 2015 9:45pm
shaggydog
Can't get you any photos at the moment but I just fitted TDCI Hard top rear speaker mounts to the rear of mine in place of the metal covers and then some speakers from a friend, then matched them with speakers in the front dashboard.
I think they were Sony ones (which is reaaaly helpful Embarassed) will get details if you can hang on till I'm home?
Sound quality is surprisingly good so does well enough for me Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #450042 28th Aug 2015 12:55pm
need4speed
The Defender-specific Alpine speakers to match the head unit aren't expensive..
http://www.ebay.co.uk/itm/Land-Rover-Defen...19f56a4e30
Post #450063 28th Aug 2015 1:55pm
CarMan
Thanks folks, I am obviously not looking for premium hi-fi sound in a 22 year old 200tdi hardtop with no headlining in the rear!
But, I want to do things right and instinctively I was thinking what is wrong with the original take-offs compared to doubling the cost of the head unit (almost) with the matched speakers (though they do appeal N4S thanks), but maybe they will be ten times better and if only double the cost it might makes good sense vfm wise.
SD - I can wait thanks
I now hear my headunit is ready to collect tomorrow Very Happy
Post #450140 28th Aug 2015 6:11pm
shaggydog
Sorry for slow response.
Here are the rear plates I got fitted with the speakers.
I ordered the wrong ones which had a step for the rear seat mounts in the tub. There is a version which is just straight along the bottom which will fit without modification.
The speakers are Sony XS-F1020SL and for my untrained ear- they are very good Thumbs Up
To fit in the front, drivers side they just slot straight in, passenger side you need a 20mm spacer.
Hope it helps Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #450888 31st Aug 2015 6:35pm
CarMan
Thanks very much SD, I've not done anything yet, but need to do something asap as I am running out of parts to fit Wink
Post #453408 8th Sep 2015 6:07pm
CarMan
Just bought the last ones Thumbs Up
Post #453726 9th Sep 2015 8:04pm
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
Have a 200 tdi HT too with no headlining. Used closed cell memory foam for the headlining. The rear speaker corners are available from Mudstuff UK, with either a 4 or 5 inch cut out. I wired the front ones into the dash after making a glove box from MDF and covering it in black vinyl, a far cheaper option which matches the dash and looks well when finished. Just make a template for the rear corners and do the same from MDF and black vinyl. The Raptor dash was added and fits in well. CB now fitted and all wiring now done for auxiliary lighting/USB etc.
Post #453818 9th Sep 2015 11:20pm
CarMan
I bought these which are now fitted, but they came with no grills and I'm struggling to find some suitable - help please Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #472517 14th Nov 2015 8:09pm
