![]() | Home > Maintenance & Modifications > Washer Jets Not Working. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Remove the pump, and make sure it's clean and working freely.
Blow all the water pipes through with compressed air. Might pay to flush out the washer bottle while your at it! Wanted, Forward Control Anything considered. |
| consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121
There is a non-return valve on the plastic pipe, up near the bulkhead. Make sure this isn't blocked up, Does it come out of the pipe with any force with it removed.
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
99% of the time is the non-return valve
| All times are GMT |
