![]() | Home > Wheels & Tyres > Strange vibration after new wheels / tyres fitted. |
Allan c. Member Since: 20 Mar 2014 Location: Aude Posts: 27 ![]() ![]() ![]() |
Hi phn, I have a similar problem new sawtooth wheels and BF Goodrich 265x75x16 tyres.
I have very noticeable vibration between 80to 90 kph, I have had them rebalanced twice and still the same problem. There is some 200grms of weight been added to these wheels. These wheels and tyres were purchased in the UK and shipped to me here in France. Have you solved the problem? I have had to remove them and put back my boosts. Thanks |
phn Member Since: 27 Mar 2015 Location: Norfolk Posts: 13 ![]() ![]() ![]() |
Hi Allan,
The issues is not yet solved but the garage says they will investigate this week. What was interesting is that several of the tyre garages I spoke to said that off road tyres in general were "impossible" to balance properly. I'll let you know what happens after the car has been to the garage. Thanks, Philip. |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Were the new wheels the Sawtooth 'Style' copies or genuine? I seem to remember somebody else on here having the same problem with copies.
I think they are copies, as they cost much less than the genuine Landrover ones.
Here's one of the threads...
http://www.defender2.net/forum/topic37566.html?highlight=sawtooth |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
Are they mud and snow tyres??
I have this on the wife's disco 3 and suffered this on a previous car too. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Yes they are BF Goodrich All Terrain TA KO2 Mud and Snow.
Do you think it is a common factor that all such tyres make the same juddering? |
Thanks for the link to that thread - its exactly the problems I have have with the wheels / tyres. |
As an alternative and if you're willing to shell out try dynamic balancing beads. Mixed reviews but wheels are constantly balanced and they work extremely well for me. Be wary dependent on whatever supplier chart you look at the recommended weights for specific tyre sizes may vary by up to 100 grammes per tyre and too few and you may experience issues that require more beads adding to them. Read the entire thread. Obviously if there is a manufacturing defect in the wheels there is not much anything can do. Have you considered getting the wheels run on a balancer without tyres to ensure they're straight and true, this is what I did to ensure a good starting point?
![]() http://www.defender2.net/forum/topic29747.html?highlight=dynamic If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Hi, the sawtooths that I purchased are copies with the BFG all terrain ko2 fitted.
I have now upgraded to a set of bowlers which I am awaiting delivery. Having had discussions with the supplier there is a possibility that the problem could be with the tyres. I will update when I have had the tyres fitted to the bowlers. Could be a nightmare if it is the tyres as I will have to get back to the UK ! |
What you need is one of these:
A professional tyre fitter/supplier that will dedicate enough time and effort to get it right! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
