![]() | Home > Maintenance & Modifications > No Stop Lights |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
It might be worth unplugging the trailer electrics loom, mine had a weird fault where the drivers side indicator came on permanently due to corrosion in the plug
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
bulbs correct way round ???
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1458
Might be a good shout, as she's now semi retired, I havn't towed anything for a while George Ta
@Roma....not changed or altered anything, just drove it |
disconnecting towing socket hasn't worked
| Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 |
My bet is you have a single filament sidelight bulb instead of a twin stop tail.
Sounds like halfords have been at it |
Unless someone's swapped my bulbs, that can't of happened 👍
Too much bass?
could be
Take the puma
| jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431
Sounds like a short somewhere i.e. bare wire rubbing perhaps. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
check the fuses Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
sorted
It was an open circuit caused by the 2 terminals touching in the o\s stop/tail bulb holder. Thanks for all the replies, hope it can help someone else out George ........... NO You'll hear the purr of the TD5 pass later |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
I'm thinking an open circuit on the earth connection between the rear lights and the chassis.
If you turn on the sidelights and brake while the sidelights are on, do the lights all go out? EDIT - my post made simultaneously with the one above. |
Cheers Blackwolf, I was hoping you or K9 read this last night
| All times are GMT |
