Home > Technical > Best way to remove these?
CarMan
As you can see, the screws are beyond unscrewing so wondering if should drill them out, like rivets?
Sorry for the very amateur question Rolling Eyes
Post #451577 2nd Sep 2015 9:14pm
Retroanaconda
Grind or drill the heads off (I would grind them, quicker and easier) and then remove the shanks with a pair of mole-grips or the like.
Post #451579 2nd Sep 2015 9:15pm
need4speed
+1
Post #451584 2nd Sep 2015 9:19pm
shaggydog
If your going to cut them off and grip them (which you probebly will do) you may as well try with a good fitting screwdriver first.
You may be surprised, mine were very similar when I first got mine but with good pressure on it it may yet wind out.
If not, mole grips and swearwords I'm afraid Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #451588 2nd Sep 2015 9:23pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Post #451589 2nd Sep 2015 9:23pm
LR90XS2011
you could try dremelling a slot for a flat blade screw driver worked for me in the past DEFENDER 90 TDCI XS,
Post #451601 2nd Sep 2015 9:41pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
3lb club hammer. Works every time! Laughing
But watch your fingers.
Post #451604 2nd Sep 2015 9:52pm
