![]() | Home > My Defender > Kiwi Defender |
I painted my headlight surrounds and grill a while ago and had fitted spotlights on my old a bar so all was in place on mine before I got the rubber a bar. As for drilling the wings, I just wrapped a good few layers of insulation tape around the drill bit about 10 mm up so when I went through the wing it couldn't go through any further and the tape doesn't damage the paint ![]() My build thread http://www.defender2.net/forum/topic17615.html |
They don't make the a bars with light surrounds anymore ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
I tried double sided tape as suggested by tj101 including big names like 3m but I just couldn't get the light surrounds to stay stuck to the tape. The tape stuck to the wing and was a right pain to get off but with each different tape I tried after a week the light surround would start to come away
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
That's not a bad idea. Just got to weigh up the pros and cons - i.e. double sided tape great because no holes, but needs removing and refitting if you every have to e.g. change a bulb (not an issue on yours with those headlights! ![]() ![]() |
Picked up the nudge bar today. There are a couple of bits missing from the fitting kit (I knew about that before I bought it so no problems there) so I'll have to do a bit of ferreting around before I get it on my car. The important bits like the bumper brackets and top brackets are all good, so it's certainly not worth getting a whole new fitting kit. I'll just have to work out the right bolt sizes and threads etc. The only slightly more problematic item is the "caps" that cover the bolt holes in the light surround pieces - but I'm sure I'll be able to find some way around that.
I haven't measured it up properly yet, but I'm pretty sure I'm going to have to relocate my DRLs about 15-20mm further outboard too ![]() |
Because sometimes, you just have to stop at the side of the road and take a photo of your Defender...
![]() Click image to enlarge This is about 2 minute's drive from my house but don't worry, we have tarmac roads in New Zealand too! :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Looking VERY good. Pickles. |
Decided I couldn't wait to fit my A-bar 2nd-hand bargain. The weather is rainy and cold at the moment so the re-spraying of the grills and headlight surrounds can wait. And I still haven't settled on the lights / light bar that (a) I like and (b) I can afford!
![]() Spent ages measuring and checking e.g. the distance from the mudguard to the bar, before realising that the natural "hand-built" quality of the car meant that the bar looked wonky when the measurements were exactly the same on both sides. In the end I relied on the old eye-ometer to make it look right! ![]() ![]() Click image to enlarge Celebrated by taking the dog for a walk at a local beach in the rain ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Your 'eye-ometer' is spot on!
Looks great... actually suits your Defender really well! ![]() |
Thanks Pete - I'm really pleased with how it looks now - not too much left to do I reckon! |
Thanks! No I used the nut and bolt method you suggested in the end - thanks for the tip. And the one about the plastic "rivets" holding the arches on - that's certainly easier than taking the headlights on and off. (Although I did lose one of the plastic centre pieces which was a bit stiffer than the others and has now pinged somewhere into the unreachable recesses of the wing! ![]() |
Took Tess for a walk at the local A&P showgrounds - couldn't resist a photo!
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Looking goo with the A Bar Andy
![]() The A&Ps are great fun, had a whale of a time at a few shows when we were last over. ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
