|  | Home > Puma (Tdci) > draining fuel filter |
| SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388      | Can't say for sure - but in this month's LRO mag in the new products section there is a tool which re-primes the fuel lines - the 'sales' blurb basically says you can't change the filter without using one. However, I wonder if one of the experienced readers has a trick? I think the tool was £90 from memory - but if you have to replace your filter or drain off water in the field then £90 well spent. I'd be keen to understand if anyone has a simple trick to do this. | ||
|  11th Nov 2010 7:44pm |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626      | some have just fill the filter and replace    Read this http://www.defender2.net/forum/topic516.ht...uel+filter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY | ||
|  11th Nov 2010 8:34pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Yes, just fill with fuel and refit but i half fill it with "Forte" Diesel treatment... i once used a dry filter and it started after 3-4 attempts. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  13th Nov 2010 9:05am |
| Posting Rules
