![]() | Home > Puma (Tdci) > Help: loss of power and black smoke from exhaust |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
First point of contact, should be Alive, really.
Though I'm guessing a split or blown off intercooler hose. Hoping you sort it fast. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Check the pipes from intercooler, and around the turbo.
Is it making any strange whooshing noises? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Greeni beat me to it!
| Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 |
Not quite sure it is a whooshing sound but intermittently have heard a loud noise from the engine. Not a rattle or anything. I suppose one could call it a whooshing sound. Will have the hoses checked once again although I had that cleared at the time of replacing the filters. Could a split hose result in extra fuel consumption and black smoke?
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
A faulty intercooler hose could. Check them near the steering shaft.
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
I had a split intercooler hose once. A whooshing sound on the highway, especially if trying to go to speeds higher than 90kmh. But no black smoke at all, and no other engine sounds either. Dealer replaced by new, but recently have switched to stainless intercooler pipes which are available for the Puma 2.4 engine.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Davie L Member Since: 04 Sep 2014 Location: Glasgow Posts: 95
Where do we get the stainless pipes from??
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
Black smoke is caused by the car running rich. So check for loss of turbo boost pressure.
Things like a egr stuck open, water gate stuck, failed boost pipe/intercooler, clogged air filter. And failing that over fueling from a bad injector or similar. But 1st get hold of Alive and see if they have had it happen before |
Many thanks for all your help. Will have them checked out and report back. Very much appreciated.
Just realized that I had mentioned Alive. My re-map is actually from BAS.
