Home > Stolen > Sawtooth spare stolen
RobKeay
My mate had his sawtooth stolen off the back of his xtech last night. It was parked on his drive in penkridge which is near Stafford. Other reports of alarms going off so be on the look out in the Stafford / Cannock area.
Post #450979 1st Sep 2015 8:43am
K9F
Unfortunately spare wheels being stolen is not uncommon. Did he have a lock on it or locking wheel nut? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #450987 1st Sep 2015 9:00am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
You can buy a locking wheel nut tool for less than a tenner on ebay so if they want it they will have it unless you go for something stronger! Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #451009 1st Sep 2015 10:04am
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
so what is suggested? is it a chain and padlock thing or is there something cleverer?
Post #451015 1st Sep 2015 10:21am
Grenadier
Lord knows why LR have not developed a retro fit spare wheel carrier whereby a plate sits over the nuts and runs in through the rear door where it is securely locked? Can't be that hard to create a metal plate, with three long threaded bolts and then have similarly located holes in the rear door. It should be an automatic upgrade for anyone who purchases an Autobiography or other variant with snazzy wheels. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #451022 1st Sep 2015 10:34am
Why would LR care if your spare is stolen? After all where are you going to buy the replacement wheel?
I use the biggest motorcycle-lock-type chain that will fit, with the most deterrent-looking padlock that will fit. I have no doubt that if the villains want the wheel they'll still get it, but it makes it difficult for the casual thief expecting just a locking nut, and hopefully would be both noisy and slow for the tooled-up professional. Just make sure if you use a chain that whatever you lock the wheel to cannot be removed or cut easily.
Also consider a loop of wire which, if cut, sets off the alarm, and I have even heard of someone who fitted a GPS tracker inside the tyre (though I am not sure what happens if you actually have to use the spare in this case - I can't imagine that it is very well balanced).
Post #451038 1st Sep 2015 11:18am
RobKeay
Locking wheel nuts were fitted.
I think all you can do is back up to a wall. Worst part of owning any Land Rover is the theft.
Post #451150 1st Sep 2015 6:38pm
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
I purchased one of these to protect my spare.
http://www.ebay.co.uk/itm/Sawtooth-Wheel-L...793510419?
Easy to fit, looks good. I did change the lock, just to ensure there were no spare keys around. Myers - Somewhere on Salisbury Plain
Puma 90 Hardtop (XS Spec)
Post #451168 1st Sep 2015 7:38pm
RobKeay
I like that looks neater than the chain I was going to put on.
Post #451217 1st Sep 2015 9:58pm
cozz
that lock looks a great product, never seen them before
they have one for a boost and one for sawtooth, wonder if they are actually different
Post #451227 1st Sep 2015 10:31pm
Rallymental
Does anyone know if the one for the Boosts will fit the Dual Finish wheels?
Post #451234 1st Sep 2015 10:52pm
If you look at the pictures you'll see the Sawtooth disc is smaller than the Boost.
There is a thread on here all about this lock, we had one to evaluate and it looked like a well thought out piece of kit, others thought otherwise
Post #451295 2nd Sep 2015 8:54am
RRUK
I like the look of that a lot. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #451308 2nd Sep 2015 9:14am
Myers
I'm happy with the lock and it's easy to fit.
The only thing I've done is to put some tape around the key hole to keep road crap out.
Easy solution, looks good and should slow down or put off anyone thinking of nicking the spare Myers - Somewhere on Salisbury Plain
Post #451496 2nd Sep 2015 6:27pm
Tough decision, isn't it? Do you reverse up against the wall to protect the spare, or nose up to the wall to protect the vehicle?
Post #451514 2nd Sep 2015 7:35pm
