![]() | Home > Technical > What have I done wrong - stub axle |
tonyhedge Member Since: 07 Jul 2015 Location: Worcestershire Posts: 101 ![]() ![]() |
Wow! Bet it's never going to look that clean again! Lovely rebuild ...
![]() 2014 90 XS SW 1997 Discovery 300TdiS (retired to stud) 1966 Series IIA 88" (now my son's) 2001 Astra - I need something to go and buy the parts when the others are off the road! |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
I see you've gone around the edges of the tank, what with?
Nice wheels, the best ever ![]() The springs will sag, mine have dropped 60mm at the rear, over a period of 6 weeks, I loaded the rear tub up with 2 spare wheels, I put a minus 1" spring on mine, I measured the top of the tub before strip down on std springs, it was 80mm higher on new -1" springs ![]() ![]() I might be putting standard springs back on, as I may opt for the NAS Spec cage and hood, instead of a truck cab, though no definite plans yet (until I find £2.5k!). Looking good so far ![]() |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
thanks! yeah pretty chuffed its finally on its feet.
new tank from paddocks, painted with epoxy mastic 2 pack paint and finally stuck some dinitrol ML3125 around the middle ![]() i did quite a bit of work on spring rates so im hoping its all going to come right ![]() |
I remember your initial post, when you got it on bidspotter...
What's the plan? Csw, rag, truck cab? Etc. |
Already have a rag top 200tdi. The body Is coming off that in one go and being transplanted on this. So kinda like a half rebuild. The top half started life as a hard top and I put a load of effort in last year to convert into a rag top. Give it another couple of years and I'll probably rebuild the body with a galv bulkhead to finish it off.
