![]() | Home > Technical > Headlight levelling switch ? |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Mine worked with the standard bulbs, have you checked the fuses? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 ![]() ![]() ![]() |
Man y thanks Richard for the quick reply. Will check tomorrow.
Regards Telshe |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Check the adjusters are there and have power. I fitted new headlight bowls last year to get through the MOT, and ended up buying ones that were incompatible with the adjusters. I took them off and achieved an MOT pass. It's done with the adjuster at 0 setting.
One of these days I will get the proper bits and put things back together. May seem obvious, but worth checking |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
If the adjuster motors etc are present but have not been used for a long time they do have a tendency to sieze. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
That you for replays but it seems l have had a senior moment. They do work but very slow to the ones on my other car. Thanks for you replays.
Terry |
