Home > Puma (Tdci) > 110 rear springs specifications
Page 1 of 3 123>
Eduardo
Hi there!
Just one question.
Checking with a friend the rear springs of ours 110 SW, we notice that the specifications given by the manual were not according with the reality. Manual said NRC 6904 Red/green for 110 (3050kg) and NRC 7000 Green/white for 110 Levelled (2950 Kg)
In fact, when we ask to GTR Customer service they answer:
"the rear springs on 07MY 110 SW 7 seat derivative is as follows: Both sides (Driver and Passenger): RKB500300 colour coded White/Green/Green"
But they dont give me the specification of the spring (lb/in) for this colour code
Somebody have it?
Thanks in advance Eduardo
Post #4497 5th Nov 2008 12:54pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
If I remember I'll look under the back of my 08 110 SW 7 and see what we get in Australia. I'm about to put heavier ones in the front as it dropped about 15mm and it handles a bit worse since putting an ARB bar and 9.5t Warn winch on the front.
Are you thinking of change the rears over? What ever mine are they handle very well even with a load in the back and 1.5t trailer behind. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4499 5th Nov 2008 1:56pm
Eduardo
dm-Td5.
No, I don't have the intention to modify the springs (at least in the medium term). Mainly is because this appear to be stiffer than the TD5 ones. Probably in the next future when we put the winch we will change the front ones as you.
Regards Eduardo
Post #4500 5th Nov 2008 2:41pm
mse
The 9.5ti on my 90 didnt drop the front and hasnt impacted handling.
The tent did a lot on handling and a little on ride height.
The handbook lists the different rates eg HD and Std for the models - but i cant help further...does parts help. Mike
Post #4508 5th Nov 2008 7:08pm
dm_td5
As I suspect, not the winch so much as the ARB bar adding to the weight. I would estimate I've added almost 100kg's to the front of the vehicle - and that's after I installed synthetic rope and an alloy hause in place of the chunk of steel Warn call a fairlead 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #4511 5th Nov 2008 8:43pm
mse
More than likely.
Ill get a synthetic rope in the future - but there arent many that will work on that winch - other things first. Mike
Post #4512 5th Nov 2008 9:03pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
I have one of those ARB beasts up front and they are seriously heavy. When I fitted it, it made the front more wallowy and the ride was harsher and it dropped a fair bit. They are seriously heavy, but I had some idiot drive in to the front of me in a twin-rear axel flatbed lorry and all it did was put a dent in it that was barely noticable, so it just got a quick touch up paint and as good as new!!! They are awesome. Just wish it did not cut down my approach angle as much. I switched to LR genuine springs and got heavy duty ones and they sorted it nicely. They are only about £70 a pair and I think the colour coding is white:white. I know a few people who change the shockc, but much prefer original springs to aftermarket ones. Well, as long as you dont need a lift!!! Having said that, after fitting my springs, it levelled out beautifully to sit level with the rear. I run a double cab with 1 ton rear springs, so it REALLY solved the problem.
Landy nut
Post #4513 5th Nov 2008 9:04pm
Eduardo
Please...
Nobody have the specs of the springs RKB500300 colour coded White/Green/Green Crying or Very sad ?
Thanks! Eduardo
Post #4517 5th Nov 2008 10:45pm
AndrewS
Eduardo wrote:
Please...
Thanks!
Ask Tim at Devon 4x4 Thumbs Up
Post #4520 5th Nov 2008 11:59pm
Eduardo
Thanks Andrews Thumbs Up .
Is he located at the Devo4x4 forum or I must ask directly for him at the sales contact?
Regards Eduardo
Post #4521 6th Nov 2008 12:47am
AndrewS
Post #4537 6th Nov 2008 9:27pm
Eduardo
Thanks a lot! Eduardo
Post #4539 6th Nov 2008 10:22pm
MK
Any luck finding out specs for the new springs?
Post #5450 12th Dec 2008 12:34pm
Eduardo
Nop,
I sent an e-mail to Tim but nothing happens Sad
Cheers Eduardo
Post #5451 12th Dec 2008 1:52pm
ugo
Italy 2007 Defender 110 Puma 2.4 SW Alpine White
no news, Eduardo ? J'aime l'Afrique
Post #27957 24th Mar 2010 11:24pm
Page 1 of 3 123>
