Home > Maintenance & Modifications > rear step advice?
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
rear step advice?
My rear step is knackered, its 12 years old and rusted onto rusted bolts.
I want a new one on, could I drill holes next to it and fit the new step there? I was thinking of dremelling it off.
Any advice please? 2001 90 TD5 CSW Alveston Red Manual
Post #445577 12th Aug 2015 8:59pm
Happyoldgit
If it's a standard fitment it will be bolted into rivnuts in the crossmember, if these won't undo or the rivnuts are spinning you will either have to drill out the bolts & rivnuts and fit new ones. A Dremel is a bit lightweight, my choice of weapon would be an angle grinder to cut off the bolt heads and then grind the heads off the rivnuts and knock them out or drill them out with a suitable drill ....bearing in mind they can have a tendency to spin. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #445583 12th Aug 2015 9:27pm
MartinK
This is my solution - cheap and simple - assuming you have a towbar...
About £15-£20, galvanized so no rust in the future (I painted my galv one black)
Like this http://www.just-tow.co.uk/single-rail-towbar-step.html
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #445787 13th Aug 2015 12:46pm
landroverdiver
I have the same as Martin, except mine is not galvanised. Bit of rust at 18-months old, but cheap as chips and perfectly placed. Little bit of black ain't and it'll be fine.
Post #445855 13th Aug 2015 5:57pm
timtom1
Thank you very much guys I will be getting a new one soon Smile I have a tow bar 2001 90 TD5 CSW Alveston Red Manual
Post #450692 30th Aug 2015 8:03pm
nitram17
step
Try http://www.masai4x4.com/#!/Twin-Rear-Step-...ory=821983 if you want something slightly different.
Post #450701 30th Aug 2015 8:39pm
Cupboard
I have the double step from Paddocks, bizarrely the galvanized one is the cheapest.
http://www.paddockspares.com/pm138g-rear-t...nised.html
I thought it would be a good idea to mount it on to a spare slider so it was adjustable. That wasn't such a good idea, because the way my slider fitting is attached on to the Land Rover means you can only use a few of the slider pin holes. and with the tow-slider and the step-slider there are only a couple of different places you can put them.
I'm wondering if my tow assemble was fitted with the bolts backwards tbh.
Post #450821 31st Aug 2015 12:20pm
