Home > Technical > 3 squeaks after engine turn off
MrOl
Hi
My 2.4 11 plate defender has recently started making 3 sequential squeaking noises from the engine bay immediately after engine has turned off...it sounds like a pump or something similar but not sure what it is or why it has just started doing it more noisily...any ideas and anything to worry about?
Post #450500 30th Aug 2015 8:39am
LR90XS2011
egr valve self clean , mine is an 11 and has done it from new, I sort of find it reassuring that everything is fine. getting more noisy may be an issue with debris build up, lots of threads on here about it. DEFENDER 90 TDCI XS,
Post #450508 30th Aug 2015 8:46am
MrOl
Does it matter that it has suddenly got a lot louder doing it?
Post #450532 30th Aug 2015 9:54am
get your head under the bonnet whilst someone else switches it off and try and isolate exactly where the sound is coming from.
Better still video it and pop it up on here for a better diagnosis.
Post #450541 30th Aug 2015 10:22am
MrOl
Have video - will upload in the morning when internet faster. Having listened again, it is doing it occasionally as engine revs up or down....it sounds a bit like a belt slipping perhaps? Hopefully video will enable someone to diagnose it.
Post #450674 30th Aug 2015 8:11pm
I have known the EGR to make noises durning running occasionally.
Usually when they are about to cause you problems. Rolling Eyes
I'm glad I'm rid of the damned thing personally but most of us can probably tell if that is it or not if you upload a video like you said, Thumbs Up
Post #450684 30th Aug 2015 8:26pm
MrOl
So got there eventually with the video...hopefully this works:
http://vid791.photobucket.com/albums/yy200/mrol/IMG_3002_1.mp4
sound is at 4s, then at 20-24s and then finally at 33s when engine is being turned off. It doesn't do the creak/squeak quite so much at turn off this time (i.e. each 'pulse' of the EGR cleaning it doesn't creak on the video, but sometimes it does do it with each pulse).
Post #450874 31st Aug 2015 5:43pm
Happyoldgit
Yup egr valve, all my 2.4's made the chukka chukka sounds at shutdown from new, yours sounds noisier in operation though. Plenty of threads on here about it, the search function should reveal them. Steve.
http://forums.lr4x4.com
Post #450886 31st Aug 2015 6:25pm
MrOl
So should I get it checked/cleaned/replaced or is it ok to run with it?
Post #450903 31st Aug 2015 7:38pm
LR90XS2011
Yes that sounds a bit painful mine is a smoother sound and quite quick. also can only be heard on shut down DEFENDER 90 TDCI XS,
Post #450919 31st Aug 2015 8:25pm
Try some Millers Diesel additive for now, see if it improves.
Post #450933 31st Aug 2015 8:58pm
MrOl
Would the brand of fuel have any bearing here?
Post #450951 31st Aug 2015 10:07pm
It can add to it yes, generally most of us use BP, Shell or Esso.
Not any supermarket brands.
Post #450960 31st Aug 2015 11:08pm
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
Had the same on our 90. Came all of the sudden.
EGR had to be replaced. 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #450971 1st Sep 2015 6:39am
Wombat2
Mine has been replaced 3 times in four years!
Post #451238 1st Sep 2015 11:00pm
