![]() | Home > Technical > Removing lt230 transfer box |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
No, on a standard setup you don't need to remove the cover.
For future reference, you can remove the lt230 from underneath the vehicle without removing the floor, seat box etc... Unless this is part of a bigger job. It's always worth removing the brake drum and backing plate though if only to keep the weight down when handling the transfer box. http://www.yorkshireoffroadclub.net/ |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
I removed gear/transfer box and handbrake all together in one go. Once removed I then split them, once all the bolts are undone the transfer box just slips off no need to remove anything else.
In hindsight the only thing I would do is loosen the bolts between the gear & transfer box some of these were bloody tight. We removed it through passenger door. ![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
Mike.s Member Since: 19 May 2015 Location: Weymouth Posts: 30 ![]() |
thanks guys - off out now to have a look at getting them out. fingers crossed this rain holds off!
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Mike from memory I am 99% sure the input gear is a decent cross drill one...as I think I swapped it over when we installed the disco transfer box
![]() N. |
cool - i hoped that was going to be the case!
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Oooo good to know you can remove it with the floors in place. I wasn't sure all of the bolts were accessible with them in.
Found my clunk culprit! Not sure how much longer this would have lasted!
Nidge - Input shaft gear was a new cross drilled gear with no wear ![]() Unfortunately i pulled my back a bit wiggling the transfer box off the gearbox - combination of tight space and an awkward position to be pulling with ![]() Will see how i am tomorrow but will probably have to be next weekend really i guess. Definitely putting it back together outside the car and back in as one unit. I think next i`d remove it as one aswell! Floor and seat box stripped out - this didn`t take that long really. I had to cut off just two bolts which had rusted up. ![]() Click image to enlarge And not much left on these splines! ![]() Click image to enlarge ![]() Click image to enlarge |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 22 ![]() ![]() ![]() |
I read a tip to cut the heads off 3 180mm M10 bolts, cut slots in the end, & wind them into the M10 bolt holes. Then you can guide the transfer box straight off or on to the gearbox. Worked like a charm for me. You were lucky the mainshaft had held. Nigel
yep - i think mine was fitted with studs on one side - unfortunately, the box was a bit stuck on them coming off, which with me tugging from the side aggravated that old back injury of mine - feeling alot better now though
![]() ![]() yes, glad the mainshaft didn`t go before now! |
