![]() | Home > Off Topic > tin tent fridge |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Hi
Just got to campsite with tin tent and it would appear the dometic fridge aint working on gas. There's a little inspect window and I can see the pilot light and ignition working. So to get the gas to light you have depress the temp control know and then let go once light (I always wait 10 secs) but each time I let go of knob the gas goes out. Failed thermo couple? Cheers |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
On the old 3 way fridges we used to fit in the Autosleepers, you could remove and clean the thermo couple fairly easily,
But remember you're playing with gas, not sure if Gase Safe applies these days. Keith |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Very likley the thermocouple. No gas safe for caravans but instead the GSIUR (Gas Safety Installation & Use Regulations) but to be fair I think as long as you are competent there shouldn't be any issues. Although I take no responsibility for you going boom in the night!
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Remove the lower vent on the out side, you should be able to get to the burner, check that it is clean , get someone to try and ignite the fridge and check the colour of the flame, it should not be yellow. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Mines doing the exact same on gas, let the knob go and the wee needle drops away again. I put the 'van in for a service and told them about this, and the cooker not working on gas either - when I got it back they said I needed the fridge and cooker looked at - well duh! Not happy with their 'service' at all.
A lot of caravan service centres do not have staff trained to work on bottled gas due to the costs of training and repeated training and testing.
I took mine into a main dealer in the North East about 8 years ago, when I booked the service they had a full list up in the reception of what a full service covered, when I arrived with the caravan they gave me a list of what they do under service, they had crossed out all checks on gas appliances and those that use 240 volt electric. It didn't leave much else for them to do. They had not altered the cost and when I questioned this they offered to knock off £20.00 from £200.00, I hitched up and drove off. I now used qualified gas (portable appliances) engineers with liability insurance to service the fridge, cooker and water heater and qualified electricians with portable appliance cover to do the electric side of the van. The local Dometic service engineers are qualified for both gas and electric . Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Thanks for the replies. Back of fridge clean.
Will have a look at know / paper idea. |
