Home > Puma (Tdci) > VIN for 90 SW (HD or standard ?? )
Page 1 of 3 123>
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
When trying to decode my VIN, I found that most of the sites I found on the internet seemed to be out of date and couldn't recognise it. Some tired to tell me it has a 6cyl petrol engine.
Now my VIN coding is the same as the infamous 2,000,000 Defender, and in this thread Supacat said that related to an extra heavy duty version. http://www.defender2.net/forum/topic38113....p;start=15
Also the BAS decoder translates it as a 90 heavy duty.
So I am wondering, is there such a thing as a "standard" 90 SW or are the decoders just not fully up to date with current VINs issued by LR?
The code is SALLDWBP7GA??????.
Has anybody got a recent MY16 90 SW that has a different code?
If there is a difference between standard and HD does anyone know what it is?
Thanks.
I just order a 90 SW XS trim. No mention or discussion of HD or not.
Post #449822 27th Aug 2015 8:40pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Our MY15 90 XS SW is also SALLDWBP7...
Nothing "heavy duty" except its thirst for diesel. That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #449860 27th Aug 2015 10:05pm
mk1collector
Does the hd refer to them all being commercial class now? Ray
My build thread
Post #449865 27th Aug 2015 10:15pm
apt100
so 3 out of 3 "HD" so far then.
@mk1collector... maybe. Would be interesting to know if there are any that aren't HD Thumbs Up
Post #449867 27th Aug 2015 10:19pm
Retroanaconda
There are heavy duty chassis' available, not sure if for 90s though.
Extra stiffeners on the main rails and such.
Post #449868 27th Aug 2015 10:20pm
WhiskyJackR
My 63 is also SALLDWBP7 ........
Post #467543 29th Oct 2015 2:31pm
apt100
@ C4 NLW thanks saw your reply on the other thread.
That's 4 out of 4 "HD" then.
Be interesting to see if there any non HD about.
Maybe for some export market??
Post #467627 29th Oct 2015 7:26pm
DSB
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Indus Silver
As is my 63 plate....
Post #467759 30th Oct 2015 9:55am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi
I think the HD referee to the rear spring rating!
As if the vehicle was ordered from the factory with a tow bar it sould have been fitted with uprated 2550Kg HD rear springs.
Road spring data for a 90
Road spring Part number Colour code
90 2 seat utility (2400 Kg)
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
90 2 seat utility (2550 Kg)
Rear - Driver's side RKB101230 Green/yellow/red
Rear - Passenger side RKB101240 Green/yellow/white
90 4 seat station wagon (2400 Kg)
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple
Just check the colour code's of your rear springs & was a tow bar factory fit option?
Post #467811 30th Oct 2015 1:07pm
apt100
@ DSB 5 out of 5 now.
@ Def90 thanks for some technical insight. Just been out with a torch to check rear springs. I wrote down White/Green/Pink for both sides. Having looked at your list, I went back to double check if passenger side was really purple but as far as I can see they are both the same and white/green/pink.
That is MY16 65reg 90XS SW. No factory tow options (had dealer fit rear tow step and 13pin electrics).
Post #467917 30th Oct 2015 7:15pm
Def90
Hi apt100
Been out this afternoon and checked the rear springs colour codes on my 2015MY 90XS SW which also has a W in the VIN.
After cleaning off all the Dinitrol on the springs colour codes, it appears I also have the same rear springs on both sides of my vehicle, White/Green/Pink.
After a little more investigation, RHD 90 4 seat station wagon vehicles from Vin BA000001 should have the same rear springs on both sides,
RHD vehicles up to Vin AA999999 and LHD vehicles from Vin BA000001 have different rear springs for each side.
So nice and simple.
Just to clarify RHD 90 4 seat station wagon From Vin BA000001
RHD 90 4 seat station wagon Rear (Heavy Duty 2550 Kg)
Springs on both sides RKB500270 White/Green/Pink.
RHD 90 4 seat station wagon Rear (Standard Duty 2400 Kg)
Springs on both sides RKB500290 Red/Green/Green.
I still believe the HD in the Vin refers to the rear spring rating but I also understood it related to the fitment of a tow bar!
This is all to the best of my knowledge as there are other configurations available.
Apologies for any inaccuracies in my previous post.
Post #468116 31st Oct 2015 5:02pm
apt100
Def90
no need to apologise. Thanks for the update. That looks just how I remember mine from yesterday.
So now we know what the HD refers to... the unknown is who/what decided what spec are vehicles were built to and whether there were any "standard" duty recent 90 SW.
Post #468118 31st Oct 2015 5:09pm
Devon-Rover
Running the VIN through the Microcat Parts catalogue which is by no means definitive but does give a good me good idea the build specs tells me that the 2 millionth VIN as posted above, tells me it has Heavy duty Suspension and Heavy duty rear springs. Apart from the jack that is the only thing heavy duty noted.
I would believe that in your VIN ranges then the it is the suspension fitted that gives you the HD moniker. There is no option for a HD chassis or NON HD. The wolf were a very special build.
So i would say you all had standard chassis the same as any other 90 off the line. Would ryan from LR like to come out of jis hole to let us know for sure?
Post #468136 31st Oct 2015 6:37pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
Finally some reasonable explanation what the HD - VIN means. Mine was also fitted with a tow bar in Solihull. I'll have to check the colors on my rear springs.... Thumbs Up
Post #468569 2nd Nov 2015 11:24am
apt100
@Devon-Rover. Cheers. I'll give Ryan a PM to look at the thread.
Post #468769 2nd Nov 2015 8:24pm
Page 1 of 3 123>
