![]() | Home > Technical > Engine driven pto |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Never seen one fitted to the engine, (though it should be possible). Plenty fitted to the PTO on the transfer box, and there's one in the for sale section currently.
The issue with that is it's not independent of ground speed, it runs at a fixed ratio to wheel speed. |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Actually far from it, you knock your transfer box into Neutral and then you have 5 forward speeds at tick over to sit at or 1 reverse speed at tick over and can sit with the handbrake on Self confessed mileage hunter |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
I have an unused hydraulic PTO kit driven from transfer box surplus to requirements...............
OK, it's independent if you're not moving/out of gear And I guess you've got the choice of high/low. |
| Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550
Isn't the issue with the puma models to do with a chassis crossmember sitting directly in the way of the transfer box take off?
I'm sure thats why the utilities companies went away from hydraulic and PTO winches. Fitting hydraulic pump elsewhere (belt driven) was seen as too much like hard work. |
| Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 26
There used to be a kit advertised on ebay, I think it was Flowfit who used to do one for the 2.4. They certainly have the bits.
| newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351
First Four, pricey, but nice.
http://www.firstfour.co.uk/products/hydraulic-drive-systems My Defender and travels |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
What are most of you looking to power from it?
If you price up a hydraulic winch vs a high end Warn winch there's not that much in it. |
I was looking at a winch, but it just becomes to expansive for how much I use a winch. I have a mate with a a PTO winch off his Tdi I have been looking at for the Tdci, but it's still not clear if it will fit. And its still its still not a cheap option with various alterations needed be made. I'm not a fan of expansive electric winches, water is water not matter how much you pay. My Defender and travels
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Here's one kit and not the one I found originally a year ago when I become interested in a pto
eBay Item No. 181785104312 I searched transit pto |
