![]() | Home > Maintenance & Modifications > Under body snorkel |
What would be the benefit compared to the "normal" snorkel?
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Purely aesthetics
![]() And "everyone " has one that runs up the windscreen pillars, Of course there maybe a very good reason and "everyone" is right for doing so ![]() |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
That's a fairly common conversion on challenge motors, some people take the snorkel through the cab but I prefer to keep it below the tunnel. The main advantage is that it prevents the snorkel being ripped off by trees but also improves visibility. http://www.yorkshireoffroadclub.net/
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 ![]() ![]() ![]() |
The shorter and the straighter the air-intake, the better. 28/02 - Loss of a good friend... ![]() In a time of chimpanzees, I was a penguin. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8243 ![]() ![]() ![]() |
mine through the cab with several bends just use largest pipe you can get away with, i am running 90mm. Cheers
Redlinemike Member Since: 27 Oct 2013 Location: Frozen north, Just off the M8 Posts: 100 ![]() ![]() ![]() |
i have a through cab snorkel with the airbox mounted in the back, piped all in 3" pipes with a tractor prefilter on top to help out the main air filter 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold Tomcat 88 |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Don't you also need to mount the end high to avoid investing water otherwise you might as well stay with the under bonnet air intake.
errrr, yes. mine ends behind my head. Cheers
James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 19th Nov 2015 9:41pm. Edited 1 time in total |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
are you sure about doing this on a 'new truck' new to you or brand new?
i couldnt cut that many holes in a brand new truck ![]() |
ill post some pictures when i get home tonight, 110 XS DC M57 + 8 Speed auto
You want to be "unusual" hows about washing and waxing your car?? Pov.spec,ftw. 2006, 110,TD5.
