Home > Puma (Tdci) > Aaarrrgghh!
Page 2 of 3 <123>
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Ironically, I've owned a Series II and a Lightweight(!) in the past, and those never seemed to bother the wife when we went out in them!
However, to go back to my first post, the issue was that these were not my 'everyday' car and were just for a bit of fun.
Am looking at the Bilstein catalogue at the moment...
spudfan wrote:
Borrow a short wheelbase series Land Rover and take the wife for drive, then let her have it for a day. You will be surprised how quickly she will warm to the Puma.
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #44829 9th Nov 2010 11:38pm
Scallops
Australia
Try ignoring the air pressure placard on the vehicle and run 28 psi front, 32 psi rear. If that doesn't work, a spoon of cement in her tea? Whistle
Post #44843 10th Nov 2010 3:26am
BruceT
South Africa
Divorce her and keep the Landy.... Very Happy
Post #44848 10th Nov 2010 9:19am
szracer
I'll pass on that suggestion...
Will you bring me some grapes in hospital? Whistle
2005 Ducati ST3
1954 Sunbeam S8
Post #44858 10th Nov 2010 10:33am
BruceT
South Africa
Laughing
Post #44863 10th Nov 2010 10:54am
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
My wife took her driving test in a (new at the time) 300DTI (I think) Defender 90 Pickup and passed first time!
Her mum/my mother in law also had a 110 V8 for years (also from new) before she learned to drive - so it was in fact my wife that bought our 110 - she's an absolute demon negotiator! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #44864 10th Nov 2010 11:00am
MK
Not all, but in most cases Landies are for boys. Now they have power steering, AC, electric windows, power brakes, synchro gears (kind of) etc. Just in case fit a mirror on the sun defelector and a grab handle on the roof. They love it! Puma 110" SW
Post #44874 10th Nov 2010 2:43pm
pom
of no real help but when i test drove a 110 utility it was like a bouncy castle with a steering wheel. I have heard they are better loaded down but empty it was horrible so I can empathise with your mrs.
On the other hand the 90 (which i ended up with) is 200% better, the suspension is still like a tractor as in no give at all but the wallowing bouncy castle mode is gone.
Pom
Post #44876 10th Nov 2010 3:27pm
mega
szracer, Ive had the same with my 110 usw it came fitted with 270/420 lbs rear springs . I have now fitted springs off the 110 sw marked green green white not sure of the lbs rate but a much better ride, the truck is the same hight at the rear. 42psi in the rear hope this helps.Mega.
Post #44967 11th Nov 2010 4:57pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Do the USW & County have different suspension setup?
Mine doesn't seem bouncy and actually seems to take potholes & sleeping policemen quite well, but it could just be that I've got used to it.
Post #44968 11th Nov 2010 5:03pm
MK
There are 280 lbs/in springs from OME. Softer than OE ones. Puma 110" SW
Post #44969 11th Nov 2010 5:05pm
roel
I think your conclusion is right based on my experience with my Camel. If you put on stiffer shocks it will help alot with kick in the neck when you have a series off bumps. Softer springs might help too but I would like that pulling a trialler.
There are shocks (I don't know with ones) I think my Koni's on the Camel had it too, that don't damp when the shock absorber is pushed together but damp the outgoing movement (at least more). That will help in this case too. Roel
2003 90 Td5 (2009-now)
Post #44971 11th Nov 2010 6:07pm
szracer
Thanks again guys - This forum really is a font of useful knowledge! Smile
I'm confused, though (sorry more questions!)...
My 110 USW has the purple/brown springs on the rear. Looking these up on the web, it appears these are now fitted as standard to all new 110s. Is this correct?
If so, I presume these are the HD (i.e. 3500kg) springs?
So, assuming that the most weight I have on the back is my race car (800kg), trailer (600kg) and tools (80kg), I should be more than OK with the 'standard duty' springs?
Which are the green & white (3050kg) ones?
If so, and having learnt from experience that it's a bad idea to make too many changes at once(!), I think my order of changes (trying each in turn and seeing if that 'fixes' things) will be:
1. New Bilstein shocks
2. Softer rear springs
3. Maybe upgraded ARBs.
I did lower my tyre pressures, and this made a small improvement in ride, at the expense of some sharpness of handling. Also, interestingly, I collected my new NAS tow step, and with the weight of this in the rear of the truck there was further improvement still. Guess since this will be fitted at the very rear of the 110 this should be weight in the right place!
2005 Ducati ST3
1954 Sunbeam S8
Post #45022 12th Nov 2010 11:48am
Glynparry25
I do belive they all thave the 3500 springs (hence why they can all be classified as N1 Tax bracket).
But when you talk about towing with it, remember that the weight of your race car, trailer and tools is on your trailer wheels...... and the weight on your truck is only the weight of the force exerted down on your tow hitch (If that makes sense).
Glyn Sheep
Post #45039 12th Nov 2010 3:25pm
MK
right, green&white are std 3050 kgs.
Basically the 270/420 behave like 300 lb/in. Therefore OME (752 I believe) has those 280 lbs/in. But I can not tell as I have the OME 755. Puma 110" SW
Post #45050 12th Nov 2010 4:17pm
Page 2 of 3 <123>
