Home > Td5 > HELP - 2003 TD5 110 Utility D/Cab Pickup purchase?
Johnnyboxer
1st ever Landy, so a total noob
Fancy a L/R and need a 110 at 6'3 (cos I can't fit into a 90) and found a nice Double Cab County spec Pickup, with 100k on it - from a local contact I know
1 previous owner (private) and I can find LR service history up to 48k and a few bits of warranty stuff from mid 2000's
Good nick, chassis looks ok - clean and tidy (side steps rotted through though, which I thought was strange) and body ok, apart from a couple of usual door handle knocks and some galvanic reaction on the rivets and one doorhandle
No oil underneath on diffs or engine bottom
Drives ok, bit of a shock driving one though - but after 15 mins I had a smile
Brakes seem not ultra powerful, clutch stiff - but I guess that's TD5 normal
So, what else to check
What should I be paying?
Post #448125 21st Aug 2015 8:15pm
Johnnyboxer
Going to view tomorrow, so any help gratefully received Wink
Post #448159 21st Aug 2015 9:21pm
g-mack
some of the usual suspects are
oil in ecu
leaking fpr (fuel)
warped manifold
diesel in oil, (injector o rings fail)
been a while since I've had a td5 so can't remember everything.
great motor though! My 109 thread
my youtube channel
Post #448164 21st Aug 2015 9:31pm
Pickles
Is there any more leg room in the front of a 110 than a 90?
Pickles.
Post #448175 21st Aug 2015 10:11pm
g-mack
nope Very Happy i guess he is thinking rear bulkhead! but we all know that is a non issue with removal kits and seat risers ! My 109 thread
my youtube channel
Post #448180 21st Aug 2015 10:33pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Best engine ever fitted to a Defender, as long as it's been looked after you should be ok.
Check if it's a std engine or tuned, see if the EGR valve is still in place, has the cat been removed, early Td5's had a problem with oil in the loom but an 03 should be fine, check the chassis and rear cross member for rot, shocks are not expensive, the clutches are notoriously stiff but can be sorted with a spring modification, as for the brakes, check the master cylinder is ok, mine had a small crack around the bolts holding it to the bulkhead, dead easy to replace though and made a massive difference to the braking power, check the door seals etc for any leaks, usual stuff which I'm sure you're aware of, if in doubt then pay for an independent L/R inspection or take a friendly forum member with you.
Can't think of anything else 'cos I've been on the plonk!
Best of luck
Post #448195 21st Aug 2015 11:05pm
Johnnyboxer
Well, I drove the TD5 all afternoon on the NYork Moors
It's slow, but gets up to 60mph eventually
The clutch was stiff and the steering at standstill heavy
Built like a tank, but the more you drove the bigger the smile, other Landy owners waved
The motor just purred, at tickover and made mo nasty noises or smoke when booted
Had it on the ramps and the chassis was amazing totally solid, original black factory paint and never waxoiled, all straight and no oil stains on the diffs/boxes or sump
Aircon was nice, as were the heated seats and because it was a sealed double cab, the soundproofing was ace - for a Landy and I could actually hear the radio
I think I may like it Laughing
Only fault I could find, was a mere smidge of oil on the outside of the ecu loom clip, under drivers seat (need a cleanout and new loom)
Post #448366 22nd Aug 2015 8:46pm
Johnnyboxer
Good buy or not?
Less than £10k, incl the Vat
Post #448633 24th Aug 2015 9:16am
steve E
Wales
You really need to put some pics up.
Hard to value a 12 year old Defender without Thumbs Up
Post #448636 24th Aug 2015 9:37am
Johnnyboxer
Here are some
Post #448637 24th Aug 2015 9:40am
steve E
Wales
Looks good.
The side steps do suffer after some time so I wouldn't be too concerned about them.
You've said the chassis is spot on and engine is sounding sweet so all's good.
Would be nice if you could knock the price down for the replacement side steps.
What's not to like Very Happy
Post #448644 24th Aug 2015 9:51am
