Home > Puma (Tdci) > VCV fuel valve
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
VCV fuel valve
Any one have any links where to buy replacement vcv valve?
Post #448069 21st Aug 2015 4:48pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
The Landrover part number is LR009837
The Ford part number is 1 514 885
The Denso part number is 6C1Q 9358 AB
http://www.ebay.it/itm/FORD-TRANSIT-MK7-2-...7963407712
http://www.amazon.co.uk/Ford-Transit-Vapou...ds=1514885 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #448144 21st Aug 2015 8:48pm
Scoobeenut
Thank you Theater you are a star Thumbs Up
Post #448178 21st Aug 2015 10:22pm
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
I too have a problem I believe from reading various threads is down to the vcv. I have found the denso part at £45 on fleabay but from the workshop manual you need to calibrate the valve with the ecm.
Further reading suggests that not all programming tools will do this. Can someone advise which tools can do this and also is it possible to have a LR dealer just do the calibration? Tommy
110 XS TDCi
Post #450978 1st Sep 2015 8:38am
I can only speak for the programming tools I have experience with, of these Faultmate can, Nanocom cannot. I can't comment on the myriad of other tools now available, but I am sure that more info will be forthcoming.
A dealer should be able to do it for you but is likely to charge 1/2 hour labour, perhaps more, so typically £40 upwards. Most indies should be able to do it as well.
Post #450983 1st Sep 2015 8:54am
landy andy
As above, no for a nanocom, yes for faultmate, but it couldn't/wouldn't do mine, so had to take mine to Alive where they used Rovacom (if that's correct) which is what the main dealers use.
Andy
Post #451018 1st Sep 2015 10:25am
Theater
https://www.defender2.net/gallery/albums/u...VCV%20.pdf Marco
Post #451193 1st Sep 2015 9:00pm
Cold_n_Wet
Norway
IID tool can too, did it on a 07 a month ago.
Looking at the old VCV I could not see why it needed changing.
Ticks over properly after changing it. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #451253 2nd Sep 2015 1:06am
bell-auto-services
The BAS2 RRC can also calibrate the VCV as well as do the pilot correction learning.
https://secure.bellautoservices.co.uk/stor...p-control/
Post #451328 2nd Sep 2015 10:06am
Cold_n_Wet wrote:
... Looking at the old VCV I could not see why it needed changing...
You never can see a difference! It puts me off buying el-cheapo ones on Ebay etc since if someone packaged their old one in the box the new one had come in, chances are you'd never know. You'd just attribute any ongoing issues to some other fault.
Post #451347 2nd Sep 2015 11:40am
