Home > Maintenance & Modifications > Bowler Sills with XS Side Steps
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Before having my Bowler side sills fitted, I struggled to find any photos which clearly showed how they worked in conjunction with the XS side steps. The few photos I found seemed to show that the XS steps were still usable once the Bowler sills were installed; however, on getting my car back from Bowler, I personally believe they are rendered pointless.
I'm glad I had the conversion done and spent an hour removing my XS steps today; however, before doing so, I took these photos as I thought they may help anyone who had a similar question in the future, especially if they have regular passengers who rely on the side steps for entrance and egress to the Defender.
View from inside the cab, looking down:
Post #448116 21st Aug 2015 8:00pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I agree, you'd be struggling to get much of a foothold on the steps.
You wouldn't be thinking of selling the steps would you Whistle
I've got the factory fit ones on mine but they've rusted through in places Rolling Eyes
Post #448126 21st Aug 2015 8:17pm
Dave_S
TBH fitting rock rails is pointless for anyone keeping the original running boards - the Bowler ones are designed for rubbing against rocks and tree trunks! So I doubt they would have ever meant the purchasers to keep steps/running boards in place, as that makes no sense.
Post #448127 21st Aug 2015 8:26pm
Dora
Dave_s I'm afraid I have to agree, I think it's a case of one or the other but not both!
I was tempted to fit the sills as I really like the look, but as I'm a short arse would really have trouble getting in on anything other than perfectly flat ground Smile
Post #448145 21st Aug 2015 8:48pm
Orchard
Really helpful thanks, makes my choice on the forthcoming birth of my 3rd child easier. Keep steps and don't go Bowler sills or, ditch the steps (take the grief at home form the shorties) and go for Drew's sill of the year 2015 Cool 2015 90 XS SW Bowler
1998 TD5 CSW
Post #448189 21st Aug 2015 10:50pm
Mr Fox
I get what Dave is saying and agree but I also hope my post helps someone who, like me, thought they may be able to get away with having both until the need to have the XS step was no longer an issue.
I know Barney12 had a similar issue and I'm sure we're not the only ones.
Post #448190 21st Aug 2015 10:57pm
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I have both fitted and find the XS steps perfectly usable, as even adults shoe toes will fit between the two, They are invaluable to small children to enable them to climb in and out of the vehicle. So don't dismiss and dispense with the steps on the basis they are completely redundant - they are not.
Post #448191 21st Aug 2015 11:01pm
Dave_S
Okay, scotia, ... but then it begs the question why you bothered fitting Bowler rock rails - at the steps will be the first thing to hit any obstacles? No?
Post #448197 21st Aug 2015 11:07pm
scotia
I fitted them because I liked the look of them, as I thought they looked better than the bit of 'tin' that LR fitted as standard. Others cover the bit of 'tin' up with chequer plate - I replaced mine with Bowler sills. I don't intend climbing over rocks and so the fact that the steps are fitted does not bother me.
I was just making the point that, in my opinion, the combination of Bowler sill and XS step IS feasible, whereas the original post was inferring that they were not.
Post #448205 21st Aug 2015 11:23pm
Dave_S
Ah, okay, get you - if its purely aesthetics, I guess I understand. Though at £500 a pair, that is expensive bling. Each to their own I guess!
I've fitted rock rails to a few trucks - normally because I intend to bounce them off things.
My current 90 has chequer on the sills from a previous owner - completely pointless, but still. If I keep it, it'll get rails at some point... likely something solid and functional though!
Post #448208 21st Aug 2015 11:36pm
Dave_S
Just thinking... I may be coming across as a troll on this, and I genuinely dont mean to be.
My main point is pretty simple - replacement sills (rock rails) are primarily meant as a first point of contact. If you have running boards and footsteps below/outside the rails, then the rails becoming pretty much meaningless. If you want to fit them in addition to steps etc primarily because they look better, then thats a personal style thing - but fundamentally its purely looks at that stage, as the main reason for having them is not relevant.
Does that make sense? Otherwise I'll just step away from the discussion Rolling Eyes
Post #448211 21st Aug 2015 11:49pm
Mr Fox
Dave, I get what you're saying and I don't view it as trolling BUT I do think we're entering the area where most (all?) modification threads go; namely: some people will fit an item because they like the look, whilst others will use that item, or another, for the functionality. The third group kid themselves into thinking they need/use the functionality when they probably don't. Therefore, it becomes a conversation of function vs fashion and justification vs denial.
I've made no bones in other threads that I will probably never use the Defenders full off-road capabilities and fitted the Bowler parts because I liked the look of them and I felt they were both better quality than the OEM parts and also finished the look of the vehicle closer to how I wanted it.
As for Scotia's point, my intention wasn't to say it couldn't be done but simply that there was A LOT less useable space on the existing step than I expected. Unlike Scotia, I personally didn't find them useful enough to keep in situ. Each to their own but I wish there was a thread with representative photos on it AND varied discussion prior to buying them. It wouldn't have changed my mind because I can work around not having them but I did think others may not be able to.
Thumbs Up
Post #448214 22nd Aug 2015 12:11am
Grenadier
AM94. Given you're not going to be using the Defender's full off road capability, perhaps you could add a spacer plate that drops the step, even if only by a cm or two, to allow users better purchase when using it to get in/out? If you do, let me know as I will be upgrading to the Bowler Sills (mainly for aesthetics!!) and hopefully retaining the steps, otherwise Mrs Grenadier will never get in without a bunk up.... Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #448224 22nd Aug 2015 5:58am
We've supplied several sets of Bowler side sills to clients with XS steps and have to agree that the step is tight to the sill and certainly not as effective as it was previously but still useable.
I don't think any of our clients intend to use the sills in anger, the only off-roading they are likely to do is mounting the pavement outside Fortnum and Masons Mr. Green
Post #448228 22nd Aug 2015 6:56am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I have to say I'm with AM94 completely on this.
Yes, the step is 'almost' useable but for people with size 4 feet and below! Very Happy
It also looks odd as is demonstrated in the photos above.
As for people fitting Bowler sills as off road protection? Really? If you genuinely wanted the protection of a rock slider I just can't beleive you would be buying Bowler sills as there are far sturdier and cheaper alternatives!
Grenadier, I don't beleive the way the steps bolt on would lead you to be able to simply fit a spacer. You would need to fabricate alternative brackets or extend the mounting arms. I'm sure there are more engineering savy people on this forum that could enlighten further.
Of course the solution to the access issue is simply to fit lowered springs! Mr. Green
Or, and I had pondered this briefly......
Try and modify one of those funky RR electric steps that slides out when you open the door. Thumbs Up
Post #448239 22nd Aug 2015 8:18am
