Home > Technical > Auto dipping rear view mirror
grafty99
Hello all!
I have just bought a bargain of eBay, £4.99 for an auto dimming mirror off a Range Rover classic, they're about £90 buy it now Mr. Green
Anyway it's here in front of me and I'm trying to find out which pins do what for the power connector. There are 6 pins and from the only picture I can find online, only the right hand 3 are used. Can anyone give me any pointers?
Thanks in advance Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #447976 21st Aug 2015 10:09am
PaulMc
Could you post up a picture of the connector it's using Question
As, the only Range Rover Classic manuals that I have, show the dipping mirror using a 3-way Econoseal connector.
Regardless of connector type, the 3 x connections will be -
Ignition-switched live
Earth
Reversing lights circuit
. Paul.
Post #447979 21st Aug 2015 10:24am
grafty99
I had worked out the three circuits, on the pictures there looks to be a link wire from the mirror to the econoseal connector Confused
1990 Vogue SE
Post #447981 21st Aug 2015 10:28am
grafty99
Ok quick update, I took the mirror apart to look at the circuit board. I've worked out that from right to left it is reverse, ground and ignition, which is good! My next two questions are;
1. What type of connector is it?
2. The next three pins on the board say DR, BAT and CAD. Anybody got any ideas?
I'm guessing DR is a live feed from the interior lights so the map lights come on with the courtosey lights? And maybe BAT is a permanent live so the map lights always work instead of just with the ignition?
Again any input would be most appreciated Very Happy Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #448008 21st Aug 2015 11:46am
PaulMc
The mirror should have a link harness from the mirror to a 3-way male Econoseal connector, which connects to the 3-way female Econoseal connector on the Range Rover's harness.
I believe that the link harness you need, is PRC8560
http://www.ebay.com/itm/Land-Rover-Range-R...1549637658
However, PRC8560 is ridiculously expensive from Land Rover - http://www.brit-car.co.uk/product.php/8999...g_assy_rrc
I believe that the connector on the mirror, is a JST VH 3.96mm N type 6-way connector -
Documentation = http://www.jst-mfg.com/product/pdf/eng/eVH.pdf
These can be bought from RS
6-way female housing -
http://uk.rs-online.com/web/p/pcb-connector-housings/7620746/
Female terminal (to fit 0.5 - 1.25mm² cable) -
http://uk.rs-online.com/web/p/pcb-connector-contacts/7620692/
You have to buy 5 x connector housings, and 100 x terminals (and a pair of 3-way male/female Econoseal connnectors) - but, this still works-out a lot less than buying Land Rover's link harness.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #448059 21st Aug 2015 3:07pm
grafty99
Briliant! thanks paul Thumbs Up
I struggled to get a picture of the correct mirror, let alone the link wire!
i have a number of kaput computers at home, i'll have a look to see if there is one of those connectors on there Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #448091 21st Aug 2015 5:41pm
PaulMc
JST VH connectors are computer connectors - so, you may be lucky and find one in an old computer.
Several connector manufacturers make 3.96mm pitch PCB connectors, which are largely interchangeable.
However, there are differences in the way that they latch.
. Paul.
Post #448094 21st Aug 2015 5:48pm
mk1collector
There's a wiring link on the bay for £25 if it helps
http://www.ebay.co.uk/itm/RANGE-ROVER-CLAS...33a669bd5f Ray
My build thread
Post #448098 21st Aug 2015 5:52pm
grafty99
great! thanks guys Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #448104 21st Aug 2015 6:08pm
Martin
Site Admin
Which clearly shows only 3 pins of the 6 used if nothing else Smile
I personally wouldn't bother with the pair of Econoseal connectors, it just adds bulk and complexity. As you're making a loom, it can be continuous to the 6 way connector.
The terminals are also available from CPC with a minimum order of 10, except they are for 0.33-0.83mm^2 cable. 0.5mm^2 cable is still plenty to power the mirror Wink
http://cpc.farnell.com/jst-japan-solderles...dp/CN18498
If you don't want the faff, RS do a kit for a single connector (and a 3 way housing):
http://uk.rs-online.com/web/p/power-supply-accessories/0381845/  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #448111 21st Aug 2015 6:48pm
Martin
Site Admin
Ignore all some of the above, I have just checked Farnell who are doing free delivery on any size order again...
Terminals (min order 5) @ 5.4p ea +VAT
http://uk.farnell.com/jst-japan-solderless...dp/2399434
Housing (min order 1) @ 14.8p ea +VAT
http://uk.farnell.com/jst-japan-solderless...dp/2399220
Just over 50p inc VAT for the connector, bargain Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #448112 21st Aug 2015 6:52pm
I've had one fitted to my 110 for a while now, if you can wait till Sunday I can tell you the pins and power
Did you get map lights too?
Post #448163 21st Aug 2015 8:31pm
dgardel
Italy
You may consider the BMW mirror
http://www.defender2.net/forum/topic16916....dim+mirror Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #448182 21st Aug 2015 9:34pm
grafty99
Thanks bpman, that would be good. I did get the map lights too. I'm hoping to work out what the other three pins do. I'm convinced that the one marked DR is live from the interior lights to use the map lights as courtosey lights as well.
I want as much functionality from my £4.99 as possible! Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #448192 21st Aug 2015 10:02pm
grafty99
Thanks dgardel I've already bought the Range Rover one. Although you never know I might end up using a different one if I can't get this one going! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #448194 21st Aug 2015 10:04pm
