Home > Technical > Tyre suitability?
YOLO110
Australia
Tyre suitability?
Early days yet with my new 90! Very Happy
But I am planning a big trip around OZ at some point and am mulling getting some HD steel wheels (Wolf) which are 6.5J X 16 with an good AT tyre to replace the standard skinny standard Michelin Latitude Cross 7.5 R X 16c on my 5.5 inch steel wheels.
The Michelin Latitude Cross has some pretty good reviews, but is it up to sand etc? I am not going to Cape York, so don't really need a full on MT tyre like the OEM Goodyear Wrangler, more like the OEM Continental Cross Contact AT.
It seems a bit nuts to just put a new set of wheels and tyres aside if I don't have too!
Thoughts most welcome please!
Cheers, Pete. Smile YOLO... You Only Live Once...
Post #447625 20th Aug 2015 8:13am
Cupboard
The Latitude is fine in slippery mud, I don't see why it shouldn't be fine in sand.
I don't know how width comes in to play on sand, I guess unlike most UK conditions a wider tyre might actually be beneficial?
Anyway, I've got a set of 7.50 Latitudes, I actually bought a set of Wolf rims so I could change them to 235 ATs and have a load more choice but I think I'm actually going to replace them like for like again. Sure they're a bit slidey in goop but so are my BF Goodrich Mud Terrains.
Post #447690 20th Aug 2015 11:46am
YOLO110
Australia
Many thanks.
So, can you fit the 7.5's on the 6.5J Wolf rims?
I thought the 7.5 section tyre would be a bit narrow for the 6.5J??? YOLO... You Only Live Once...
Post #447693 20th Aug 2015 12:15pm
Retroanaconda
The 6.5" wide Wolf rims will take either 7.50s or 235s, they're good versatile wheels. Standard 5.5" wide rims can take 7.50s but not 235s.
I had the Lattitude Cross on my 90 for a while, they are a good tyre there's no doubt about that. I changed to 235s, first in Continental Cross-Contact (which dissapointingly wore out in less than 35,000 miles) and now I've just sourced a set of BFG All Terrains in the same size to replace them.
I would certainly go no wider than 235, mainly because in my opinion wide tyres look stupid, but also because for my use a thinner tyre is better. Conditions down under may be different, but I would say a set of BFG ATs in 235 would be a good bet for your trip. The Lattitudes in 750 would as well, perhaps consider what size is more available in the areas you are travelling to - in case you bust one?
Post #447725 20th Aug 2015 2:09pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I've just swapped my standard 5.5" rims with 7 year old 7.5 Michelin tyres (which I've been very pleased with) for Wolf HD rims, and have gone for 235x85 Cooper A/T3s.
Unfortunately too soon for me to give a verdict on them, as I've only driven about 5 miles since, but I'll update when I've put some miles on.
I spent a lot of time researching AT tyres before deciding on the Coopers, and found it very hard identifying truly subjective opinions, same goes for unbiased testing. All I really went on in the end is the EU markings and the manufacturer's suggested 60/40 (road/off road) split, which I think should best suit my needs.
My previous Michelin 7.5 tyres were the older version of the Latitude Cross, and I found them to be great all-rounders and far superior in ALL conditions (except dry tarmac) to my previous (to that) 265 wide BFG ATs.
So they are the only ones I can offer opinion on - but that's in the UK and I agree with others that sand driving my benefit from a wider tyre.
PS - my 2nd choice would have been 235 Conti CrossContacts - if a new-take-off set had come up at the right time (without alloys attached), I probably would have gone for them.
Post #447739 20th Aug 2015 3:07pm
leeds
On a 25,000 mile trip around the Australian outback we used 255/85/16. BFG M/T.
Picked up two punctures, both from roof sheeting bolts in towns. Aussie builders are as careful as UK builders as to where they leave their unwanted screws and nails!
Depending where and how you are travelling does have an effect on tyre choice. If travelling as part of a group try to ensure some common sizes amongst the group. Travelling solo in the more remote areas 2spares plus a couple of inner tubes. Also a GOOD compressor.
Use tyres that are reasonably new with good tread depth. Old tyres tend to be perished and more prone to punctures/pressure loss.
Soft sand a wide tyre reduces ground pressure, and a tall tyre gives better ground clearance. which 255/85/16 gives you.
Brendan
Post #447896 20th Aug 2015 10:55pm
YOLO110
Australia
Thanks for the replies guys.
I think I will still get the HD wheels, because the look rubber COOL!
And given the info, fit my new Michelin Latitude Cross 7.5c X 16R to them. The tyres do get some good reviews.
My main concern was would the tyre be too narrow for a rim that is 1" wider.
Carry 2 spares indeed!
Cheers, Pete Smile YOLO... You Only Live Once...
Post #447898 20th Aug 2015 11:03pm
ericvv
Think with Wolf wheels the general practice is to put 235 wide tires. And that size always looks good on Defender, just a perfect fit, and still a factory standard too. So if you buy those wolf wheels why don't you consider the just lauched new version of one of the most praised AT tires, the BF Goodrich All-Terrain T/A KO2. Would be one of the best possible looking and performing combinations I think.
You then could decide to keep or to sell your standard wheels/tires combo a bit later, wouldn't be surprised you would decide to sell them. Laughing
Eric
This one here I mean
http://www.bfgoodrichtires.com/tire-select...re-details You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #447911 21st Aug 2015 5:38am
YOLO110
Australia
IF I can safely put my Michelin on the Wolf's, I would do so I think. They get a good review.
So, that is the big one! Question
I hear about those BFG reviews etc... but personally, I dislike the BFG with all their bling white lettering!! Laughing I know they can be fitted 'inside out' but you can still see the white stuff. It does not suit a classic Keswick Green 90 IMHO! YOLO... You Only Live Once...
Post #447918 21st Aug 2015 6:03am
ericvv
^^ You are right about that. Thumbs Up
IMO what suits a classic Keswick/White Defender the best of all, is the GG TR in 235 width which still was the standard fit back in 2008 when I bought the SVX. Later replaced by the Conti, which looks too modern for a Defender I think.
My summer wheels and original GG TR set were stolen from our property back in Jan, and I have been thinking of waiting for these new BFG A/T KO2, also gave some thought about the Conti, but in the end reordered new GG TR. Which needed intervention from Conti Germany, as it meant a special import into Switzerland by Conti (who own GG) because the GG TR even if they remain in production, are not imported into Switzerland anymore. Happy I did just that, for me that is a classic tire which suits a Defender very much, and which in my case is just perfect, quiet, but admit, I drive 100% on asphalted roads, except for the gravel at home. Laughing
Eric
Post #447921 21st Aug 2015 6:18am
Cupboard
The army put 7.50s (XZLs) on Wolf rims after all Laughing
Post #448107 21st Aug 2015 6:13pm
