![]() | Home > Maintenance & Modifications > LED Bulb minefield - pls help? |
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
The RDX / Wipac replacement LED units are your best bet. The LED indicators require a new variable flasher relay, which is fairly straightforward to install and comes with both kits as far as I am aware (I have the RDX lamps all round). Fitting LED bulbs into the standard lamp units is technically illegal as the lamp unit is E-marked for a filament bulb, not an LED. I have tried various LED bulbs in the standard lamps and none were that effective or satisfactory. The LED lamp units are far preferable with a much better output and they are E-marked. 2005 Td5 | 90 Station Wagon | Tonga Green
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
RDX via E-bay or Paddock spares website for Wipac.
I'd recommend the RDX relay though. LED side repeaters are available from Brendan @ 4x4 Overlander (site sponsor) I have RDX as above too, I am biased of course but heard just as good things about Wipac's version. |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
You can not just swop the standard filament bulbs for LED clusters. All obligatory lights have to be type approved (read E mark these days) this includes side lights and indicators. The standard lights are type approved for filament bulbs. Replacing a blown filament bulb with another filament bulb is legal. Replacing a filament bulb with a LED clusters is illegal as the type approval is invalid. The original manufacturer got type approval for a filament bulb and would not have tested it for a LED cluster. Best legal solution is to buy a complete E marked LED unit. Brendan |
| mlightfoot Member Since: 10 Jan 2009 Location: Cheshire Posts: 86
Thanks all. I have the SVX rear LEDs from Mobile Centre but the fronts now look a bit left-out
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
I tried some LED bulbs for the indicators and they were pants, more or less invisible in daylight so I gave up with them. Now I've gone for the Wipac clear LED lamp set like these -
http://www.mudstuff.co.uk/front-rear-73mm-led-lamp-kit.html They are a far better solution, more robust and more reliable |
Have you found the Wipac relay okay?
Yes perfect, once adjusted properly it works just like a normal one
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265
Putting an LED bulb into a fillaent holder to shine through a fillament lense is illegal.
Sealed manufactured units are legal. all to do with light waves, angles of refraction ya de ya. so to the OP - LED bulbs = don't. Get a set og units and you;ll be fine. TY&GN 10 years in a WOLF, WIMIK and Snatch and this is all I have to show! |
