Home > Td5 > Water temperature gauge show going hot
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
These days the TD5 water temperature gauge niddle move over the middle to the red zone, sometimes just a bit over the middle, but sometimes goes closed to the red zone, but it goes back to the middle after few minutes??? Then will go over middle again...
Does it mean it's electricle error, or something else!
I did cold check no coolant lost!
Mr. Green
Post #447303 19th Aug 2015 10:21am
excossack
My gauge had a habit of bouncing around, normal to hot to cold back to normal. In the end I replaced the coolant temp sensor by the top hose/cylinder head side and that cured it. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #447345 19th Aug 2015 1:23pm
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
i do hope this is not the case with you but mine did this and at the same time i noticed my heating inside was getting quite hot and then slowly got cooler then hot again, found my expansion bottle an hoses very hard and then after about 3 months my head went. keep an eye on the heating...
Post #447490 19th Aug 2015 7:44pm
RF3777
What was the problem?
Post #447574 20th Aug 2015 2:10am
roel
If your td5 rally gets hot it will first move a little higher, like yours shows and then suddenly jump to the red zone. So that is a normal behaviour, but as yours jumps up and down quickly I would suggest, like as said before, to check/change the temp sensor.
If it really gets hot the ecu will reduce power and it will take some munites before the temp gauge will go down. Roel
2003 90 Td5 (2009-now)
Post #447603 20th Aug 2015 8:40am
excossack
This is what mine was doing
Regards
John M0VAZ
Post #447607 20th Aug 2015 8:45am
RF3777
I have check both fans works, a small fan start to work after air con turn on, anything to do with air con?
Post #447648 20th Aug 2015 10:47am
RF3777
So your TD5 getting cold Rolling with laughter
Post #447649 20th Aug 2015 10:48am
Redlinemike
Scotland 2004 Defender 110 Other XS DCPU Auto Bonatti Grey
run an additional earth from the ecu mounting plate to the battery,
it "should" cure that problem of the guage moving about on its own 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold
Tomcat 88
Post #447683 20th Aug 2015 12:33pm
RF3777
Redline kid, would you teach me how to make the earth point to ECU and battery? Bow down
Little update, the temperature niddle move to a bit cold side when I turn on the heater, how funny? Mr. Green
Post #447686 20th Aug 2015 12:39pm
Redlinemike
to easily prove /disprove take a langth of wire approx 5ft long, i normally use 2 core & terminate both ends together, small 6mm ring terminal at the ecu side & a 8mm ring at the battery side,
remove one of the ecu mounting bolts & secure the cable to it, on the battery side connect the other end to the NEGATIVE post on the battery,
basically you are bypassing any flaws in the earth path between the ECU & battery, 110 XS DC M57 + 8 Speed auto
ORA jeep- Sold
Tomcat 88
Post #447687 20th Aug 2015 12:43pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
As above. Common issue on the Td5 Thumbs Up
Post #447688 20th Aug 2015 12:46pm
RF3777
The battery is on the passages side, and the ECU is on the driver side...
How can I connect the cable from battery negative to ECU bolt?
Post #447766 20th Aug 2015 5:29pm
Disco_Mikey
By running a new wire...
Post #447793 20th Aug 2015 6:59pm
RF3777
Done this morning
Post #447902 21st Aug 2015 3:47am
