![]() | Home > Technical > Removing LT77 Gearbox |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 863 ![]() ![]() ![]() |
From my memories of doing this to my own 200tdi defender when working on the drive I am sure I only removed the viscous fan from the front end to stop it hitting the cowling. Hoses should be fine. I also have a vague memory of the transfer lever or gear lever stub being a pain to get past the seatbox (transmission tunnel out obviously) but can't remember if it is necessary to remove the selector housing before removing the boxes?
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
No need to at all. Take the fan off if you're worried or something under the flywheel housing to stop it drooping down.
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Keep up the good work Mike.....it will soon be good as new
![]() I could do with your welding skills on the latest yoke I bought..... Nigel. |
Mike.s Member Since: 19 May 2015 Location: Weymouth Posts: 30 ![]() |
Cool - hopefully, i`ll get away with just removing the floor and gearbox tunnel to gain access
![]() Cheers Nidge - getting there - truck is used pretty much everyday. I was putting up with the crunchy 3rd gear and double declutching it, but have been keeping an eye out for a 2nd hand one for a while. Picked one up this week which was a recon fitted to an ex mod 110 which has a slightly lower 1st and 2nd gear - will hopefully pull away a bit quicker with the disco transfer box and my big wheels. I`ve also had it tuned up by a guy who loves his diesels and it really flys now ![]() Should update my thread really! |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I would definitely be interested to hear about that ![]() Self confessed mileage hunter ![]() |
