![]() | Home > Puma (Tdci) > Just to be aware: LTB00177 |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Mine was already had this problem 4 month ago....
Technical Service Bulletin No.LTB00177 09 October 2008 Subject/Concern: Brake Vacuum Pump Seal Oil Leak Models: Defender (LD) 2.4L Diesel Only 2.4L Diesel Only VIN-range: 7A732615 Onwards Markets: All Section: 206-07 Summary: Oil leaking from the brake vacuum pump front oil seal. Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31. Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)). Parts Required: Description Part Number Quantity Brake vacuum pump LR012183 1 Gasket LR004381 1 Labour Time: Operation Description Operation No. Time Install a new brake vacuum pump 70.15.19 0.7 hours Repair/Claim Coding: Causal Part: LR012183 ACES Condition Code: 42 Defect Code: Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 ![]() ![]() ![]() |
Happened to me aswell, got it towed and they installed a new one but dont know if its the improved one
![]() Ah well atm its still going good ![]() Verdone |
I just ask my dealer if they put the modified one or not.
No answer yet.... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
In South Africa most if not all Puma TDCi Defenders have had this problem due to the hot dusty conditions as far as I understand. Most have been replaced with the old unit, I think the new unit was only released this month
Thanks Fontuin
Just I receive the answer from the dealer: Was replaced for the old one. New one was on the market from Sept. So, we are waiting to have the same trouble again ![]() ![]() Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
This makes me b
I was wondering about whether this was the case, the problem with the Transit was/is probably not as severe because it would not be used in hot dusty condtions to the same extent that Defenders are (we don't even have transits here in SA).
Not a question of if, it is a question of when, the old pump will start leaking at some stage in the conditions I use my vehicle in. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I'm on my 5th
![]() ![]() I had a new one (new type) replace 4-5 days before going to Morocco it failed within 2000 miles. I was not allowed to take a spare as they are in limited supply and Land Rover said that one has been allocated to my car already so tough. Luckily for me the support vehicle had 2 spares. Also Nick at Yeovil Land Rover was on stand buy to ship one out for me |
I am thinking of (if I ever get mine back ) buying a spare for next years trip. Is it easy to fit? |
Mine just failed, engine is covered with spatters of oil again ffs
![]() Verdone |
[quote="The Boy"]
Yes ![]() |
I got it back with no new vacuum pump
![]() ![]() Anyone know whats going on???? U pay plenty of money, i dont care if it rains inside or all that but i do expect to it to be mechanically in a good state no?? |
WHAT?
If I understand yours will be out of service for one month? That's not good... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
No they gave it back since its not that severe yet, since ive had the problem once i checked regurly and saw it was beginning to leak again
![]() So i took it in to the dealers and after a week i got it back with done what i asked except the vaccum pump since all the old ones r recalled and their are no new ones!!!????!!!! I wonder if anyone can check that cause i hate driving with oil spilling around ![]() Verdone |
