Home > Technical > defender xs 90 noise while driving
Lander2015
Scotland 2015 Defender 90 Puma 2.2 XS CSW Barolo Black
hi all.
I finally convinced myself to get a defender and I got a 2015 one, so it is my first time with this kind of beast
Being previously a land cruiser guy, I am finding this beast very interesting
however a doubt. and perhaps it is normal
When the gears are not engaged, and i rev the engine it is sound smooth and nice and tight.
however as soon as I engage any gear a noise appear like something is loose, sometimes the noise is not present at all and so times is there sometimes strong than others times. the sound can be described like if a rattle is being shake
the car has just made 200 miles from new.
any advice. should I worry or it is just normal.
M
Post #446241 15th Aug 2015 12:58am
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi M
Was it making this noise immediately you collected it, or was it OK then? Either way, best take it back to the LR dealership and let them take a look at it - presumably when you had a demo drive in their vehicle, it did not make this noise.
Post #446259 15th Aug 2015 7:59am
K9F
Doesn't matter when the noise started, it's under warranty. Exhaust heat shield perhaps? Take it back as suggested, we can speculate all day what it 'might' be. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446263 15th Aug 2015 8:41am
Lander2015
Hi thanks,
the noise is since I took it out, to described it better, is more like a loose bearing.
I will contact the garage anyway, but i just wanted to know if perhaps this is normal since is the first time I have one.
the noise as i mentioned is only when the gears are engaged, for example if i am running and select neutral and rev, the noise is not present, as soon as it is engaged, then is present and it goes with the speed. at high speed and high gears tend to disappear
perhaps overly worry, but i will check
cheers pals
Marc
Post #446266 15th Aug 2015 9:09am
Martin
Site Admin
Doesn't sound normal to me  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #446347 15th Aug 2015 6:13pm
